Too hot?
Old Jul 31, 2012 | 05:24 PM
dakota_raven's Avatar
dakota_raven
Default Too hot?
Hey guys! For the last couple of days my truck's fan is been a little louder that usual. I have never paid attention to it but i looked today at my temp gauge and it was a little too high than usual..
What do you think??
Old Jul 31, 2012 | 05:58 PM
sethgtrx4's Avatar
sethgtrx4
shoot, I think your golden...is that temp gauge reading with th AC on? I live in vegas, and my temp gausge is either EXACTLY at he half way piont or a little above.
Old Jul 31, 2012 | 06:41 PM
JoeyDMG's Avatar
JoeyDMG
That's where mine sits if it's not hot outside. When it's hot it'll go up a little bit over half and drop down. That had me scared enough to order a 180 t-stat.
Old Jul 31, 2012 | 07:25 PM
Your fine. The fans clutch is working correctly, making the fan pull more air (hence, louder).
Old Jul 31, 2012 | 08:12 PM
sethgtrx4's Avatar
sethgtrx4
Do either of you guys know what the stock thermostat is? Ive read on here that a 180 stat is a good idea. I have hood vents and a flexalite E fan...the temp still gets up there. especially towing. have to pull over ocasionally.
Old Jul 31, 2012 | 08:16 PM
stock is 195
Old Jul 31, 2012 | 09:23 PM
Holbrook.Jeremy's Avatar
Holbrook.Jeremy
I did the 180 and while the gauge does sit lower montering with TOrque doesn't show a difference in coolant temp. With the Mark VIII fan it's never gotten the temp lower then 190.
Old Jul 31, 2012 | 11:03 PM
popsnbeer's Avatar
popsnbeer
do you guys see your temp fluctuate a lot? Mine will go about 2 needle widths above the 1/2 way mark, but then if I'm going down a hill at speed it will drop down to 1/4. I've just never seen this happen in any other vehicle except an old s-10 I had and they replaced the water pump as a result.
Old Aug 1, 2012 | 12:48 AM
jasonw's Avatar
jasonw
Site Moderator
Mine never fluctuates. Its exactly where your picture shows it, and A/C on or not, it never moves for me.
Old Aug 1, 2012 | 07:33 AM
Mines pretty steady. Had another car once that did what yours is doing and it ended up being the head gasket on its way out.
