Random Temp light??
Old Sep 21, 2012 | 12:09 PM
KS Cowboy's Avatar
KS Cowboy
IF you happen to have a scan tool, hook it up and if the gauge is reading normal, it might be your PCM. THat is supposedly what is happening to my truck. It has been over a month, and this is where they are at now.
Old Sep 21, 2012 | 04:44 PM
littleBIGdodge's Avatar
littleBIGdodge
I was reading the FSM last night, and i thought i read somewhere (now i cant find the page) that a bad battery temp sensor on the battery tray can cause certain codes to be or not thrown. I just looked but could not find any type of battery tray sensor though... I believe if the battery temp sensor is reading too high or too low it can effect the readings of the trans temp sensor? I could be wrong but i cant find what page it was to verify this. I need battery cables ASAP, They became extremely corroded over the last time i popped the hood a two months ago, which coincidentally was just before i started getting a tranny light on the dash. I bet my crap cables are screwing up my electrical system, luckly i just ordered a new set. On mopar wholesale parts.com, the negative battery cable item description also says "Part serviced with engine and transmission wiring harness."
Last edited by littleBIGdodge; Sep 21, 2012 at 06:30 PM. Reason: no battery sensor could be found
Old Sep 21, 2012 | 07:46 PM
damyankee84's Avatar
damyankee84
OP here....All I did was disconnect my battery, cleaned the terminals and let it sit for awhile, then hooked it back up and havent had any trouble since.
Old Sep 29, 2012 | 02:29 PM
viper359's Avatar
viper359
My truck does this as well, for the last year at least, and it just pops out of the blue, happens for a couple of weeks, then I won't see it for months. Usually happens when i am in park, idling. Lasts a 30 seconds tops. I think I have posted about it before as well. I have 116000KM's on my truck, and wouldn't doubt in the least its a way to get people to go to the stealership and get suckered into a tranny service.
My mechanic has been under my truck twice in the last year, replacing my entire front end for the most part, and replacing my brakes all around. I beat the living sh** out of this truck, if I had a leak, or any fluid related issues, he would have noticed, since he checked them all for me. The only "leak" I have is the small lake that is created under my truck once I shut my truck off, and have been running the AC the whole time, which I run wayyyy to often.
Old Sep 22, 2016 | 10:27 AM
GatorB0b's Avatar
GatorB0b
Default Transmission Temp light random. Dumb it down.
I racked my brain on this stupid light too. "keep it simple stupid" a Lockheed engineer once said. The I know everything person that I am, It pays to look at the owners manual from time to time. I was incorrectly checking the Trans fluid level the whole time (cold and engine off). There are 7 steps to properly checking the fluid level. Turns out I was checking the fluid the wrong way and I was actually a quart and a half low! That will cause you fluid to heat up! Sure enough, after adding the quart and a half I was low, the problem with the light went away. Lesson learned, don't over analyze the problem.
