High Idle in Park
Old Aug 19, 2012 | 11:24 PM
dimesismoneytoo's Avatar
dimesismoneytoo
Default High Idle in Park
My truck has been acting up as of late. It seem as though it is idling quite high. 1500 RPM in park. Once I shift into drive it goes back down to about 1000 RPM. When shifting I get a very large kick when shifting into reverse, then shifting into drive from reverse another large kick.
Wondering if anyone else has experienced this and what could possibly be causing this. What to do to fix it would be helpful also.
Thanks
Old Aug 19, 2012 | 11:25 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
Throttle Position Sensor..first check for a dirty butterfly valve on the throttle body though!
Old Aug 19, 2012 | 11:30 PM
dimesismoneytoo
How would I go about check that? Just pull the air box off and look in there?
Old Aug 19, 2012 | 11:42 PM
06Dak4.7Silver
It is the sensor on the side of the throttle body (top one)..if you are looking at the engine bay then it is on the right side of the throttle body. The one on the bottom is the idle air control valve and the one on top is the TPS. Cleaned both of them with an electrical cleaner aerosol spray. To clean the butterfly valve just remove the intake tube from the throttle body and get any carbon buildup off of the golden plate you see in there. Spray a cleaner on the rag and then carefully remove it..or just unbolt it and clean it off the truck
Old Aug 20, 2012 | 01:40 AM
jasonw's Avatar
jasonw
Site Moderator
06Dako4.7Silver has good advice. One extra little thing I'll add to it... do NOT manually move the TPS around by hand. It is a fairly fragile sensor.
If you do, or of the cleaning doesn't solve it, no big deal. They are not that expensive, and can be found at any auto parts store. If I recall correctly, O'Reillys has one made by BWD that is about $30-$40, and has a lifetime warranty. I think it was a few dollars more than Advance or AutoZone, but that lifetime warranty (and I tested it, they do honor it) is very handy for small sensors.
Old Aug 20, 2012 | 08:02 AM
Do you have a fastman throttlebody?
Old Aug 20, 2012 | 03:37 PM
dimesismoneytoo
Stock throttle body.
Old Aug 20, 2012 | 04:54 PM
kjpark's Avatar
kjpark
you could also check the MAF too, thats what eased out my idling on my old truck, not sure how it affects shifting though.
Old Aug 20, 2012 | 06:00 PM
dimesismoneytoo
The kick while shifting is probably caused by the high idle in park and neutral. The transmission is supposed to shift into drive at about 1000 RPM and when the truck in idleing at 1500 RPM it puts extra torque on the transmission, thus causing that huge kick.
Old Aug 20, 2012 | 08:56 PM
Eimer123's Avatar
Eimer123
We do not have a MAF.
But more idle issues are caused by a bad sensor, but mostly on our truck, a dirty sensor.
4 possible senors. Could be only one, could be all 4
1. Throttle position sensor needs cleaning - (located in throttle body)
2. IAC (idle air control) needs cleaning - (located in throttle body)
3. IAT (intake air temp) needs cleaning (located in air intake tube)
4. Cam position sensor needs replacing. (located on the end of the engine)
You probably have a dirty IAC <--- my vote
