Transmission Drain Plug
Old Nov 1, 2012 | 01:43 PM
dimesismoneytoo's Avatar
dimesismoneytoo
Default Transmission Drain Plug
So, I have a transmission that is supposed to be delivered tomorrow and I was wondering if anyone had installed a drain plug on the trans pan. It would make it much easier to change fluids instead of having to drop the pan and getting oil every where.
Old Nov 1, 2012 | 02:19 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
I havent on this truck, but I have on other vehicles. Its a cinch; however you need to room the pan initially.
http://www.autozone.com/autozone/acc...er=266070_0_0_
Just buy something like this, drill and install in a spot with a good clearance and voila!
Old Nov 1, 2012 | 03:37 PM
KS Cowboy's Avatar
KS Cowboy
check this site out. they look like they have a pan that has the bung hole already in it. It is actually for the trans temp sensor, but you can put a plug in it.
http://www.transmissionsone.com/45rf...s_from_pat.htm
(scroll down till you see it.)
Old Nov 9, 2012 | 12:05 AM
Blown287's Avatar
Blown287
I hope this helps.
https://dodgeforum.com/forum/3rd-gen...rain-plug.html
