TSB Software Flash
This may be on the forum somewhere already but this upgrade made a world of difference in my Dakota's transmission. It is much smoother and it took the shudder out of the TC clutch.
I would recommend it if your Dakota is included. Note the last paragraph for transmission improvements.
NUMBER: 18-011-12
GROUP: Vehicle Performance
DATE: March 15, 2012
THIS BULLETIN SUPERSEDES SERVICE BULLETIN 18-056-11, DATED DECEMBER 22, 2011, AND 18-030-11 DATED JUNE 14, 2011 WHICH BOTH SHOULD BE REMOVED FROM YOUR FILES. THIS IS A COMPLETE REVISION AND NO **ASTERISKS** HAVE BEEN USED. THE ADDITIONS ARE THE INCLUSION OF 2010 MODELS WITH ENGINE AND TRANSMISSION SOFTWARE ENHANCEMENTS FOR ALL VEHICLES AND YEARS.
HELP USING THE wiTECH DIAGNOSTIC APPLICATION FOR FLASHING AN ECU IS AVAILABLE BY SELECTING "HELP" THEN "HELP CONTENTS" AT THE TOP OF THE wiTECH DIAGNOSTIC APPLICATION WINDOW.
THE wiTECH SOFTWARE LEVEL MUST BE AT RELEASE 12.02 OR HIGHER TO PERFORM THIS PROCEDURE.
SUBJECT:
Flash: MIL Illumination With Transmission And Driveability Improvements
OVERVIEW:
This bulletin involves flash reprogramming the Powertrain Control Module (PCM) with new software.
MODELS:
2009 (HB) Durango2009 (HG) Aspen2010 (DJ) Ram 2500 Pickup2009 - 2010 (DS) Ram 1500 Pickup2009 - 2010 (DH) Ram 2500 Pickup2009 - 2010 (DC) Ram 3500 Cab Chassis2009 - 2010 (ND) Dakota
NOTE :This Service Bulletin applies to HB/HG/DJ/DS/DH/DC/ND vehicles equipped with a 3.7L, 4.7L or 5.7L engine (Sales Code EKG, EVE, EZC, EZD or EZH) and a 4 speed 42RLE or 5 speed 545RFE or 6 speed 68RFE automatic transmission (Sales Code DGV, DGQ or DG7).
SYMPTOM/CONDITION:
The customer may experience a Malfunction Indicator Lamp (MIL) illumination. Upon further investigation the Technician may find that any of the following Diagnostic Trouble Codes (DTC's) have been set.
i.PO5OD - Cold Start Rough Idleii.P2181 - Cooling System Performance has been setiii.P0935 - Line Pressure Sensor Circuit High All RFE transmissionsiv.P0300 through P0308 - Multiple and Single Cylinder Misfire. This condition can occur when the vehicle is started cold and the driver immediately places vehicle in drive and applies heavy throttle.
Driveability and Transmission improvements are also included with this software release. These changes consist of the following:
a.Enhanced clutch protection for more robust torque management during repeated fore and aft movement (rocking vehicle) all engines.
b.A revised torque convertor lockup schedule that will reduce transmission temperatures in Tow/Cruise mode All models equipped with RFE transmission.
c.A Clunk sound or feel a shudder when the cruise control resume switch is pressed. This condition is most noticeable after the brakes were pressed to cancel cruise control and then the resume switch is pressed All models equipped with RFE transmission.
d.A shudder or shaking feeling when a wide open throttle (WOT) event is performed by the customer. This is most noticeable after the transmission downshifts during the WOT event. This condition will stop once the transmission upshifts All models equipped with RFE transmission.
e.A shudder or shaking feeling when accelerating from a stop under moderate throttle. This condition will stop once the transmission upshifts All models equipped with RFE transmission.
f.A shudder or shaking feeling after the transmission downshifts. This condition will stop once the RPM's drops All models equipped with RFE transmission.
g.Harsh or noisy natural to reverse shifts All models equipped with RFE transmission.
h.Harsh 4-3 downshifts. This condition happens when there is no throttle applied and the vehicle is coasting down. All models equipped with RFE transmission.
i.Harsh 1-2 upshifts. This condition happens under moderate or heavy throttle conditions All models equipped with RFE transmission.
j.Engine knock condition. This condition could happen when a wide open throttle (WOT) event is performed or cruising at 5400 RPM or above All models equipped with RFE transmission.
k.Hard start or long crank condition at 0°F (-17°C).all 5.7L DS and DJ models equipped with RFE transmission.
NUMBER: 18-011-12
SUBJECT:
OVERVIEW:
MODELS:
SYMPTOM/CONDITION:
