Factory command not working!
Old Nov 20, 2012 | 09:32 PM
mopar204's Avatar
mopar204
Default Factory command not working!
For the longest time i had a check engine light on which i thought was the problem to my command start not working but yesterday i got the problem fixed and my check engine light is now off for good. The command start still does not work though. It will flash once and lock the doors but doesn't start the truck. Does anyone have any ideas?
Old Nov 21, 2012 | 07:15 PM
mopar204's Avatar
mopar204
I guess no one has any idea what it could be :s
Old Nov 21, 2012 | 08:34 PM
What was the code? What did you do to get the code cleared? Did the command start work before the CEL came on or did it quit at the same time the CEL came on? What exactly is command start? I've never heard of it.
Old Nov 21, 2012 | 09:47 PM
DaKoCuN's Avatar
DaKoCuN
Have you checked the batteries?
Old Nov 22, 2012 | 12:47 AM
jasonw's Avatar
jasonw
Site Moderator
"Command start" is another way of saying "remote start" I believe.
Dumb question first... you are pushing the button twice, and not just once, yes?
Old Nov 22, 2012 | 03:14 AM
mopar204's Avatar
mopar204
Yes i clicking the button twice lol
And no i haven't checked the batteries, but everything else works and the lights flash once.
The CEL has been on since i purchused the truck, and no i havent cleared the code i just fixed the problem which was p0073 which is ambient air temp sensor and the engine light is no longer on.
Old Nov 22, 2012 | 07:44 AM
Factory or aftermarket remote start?
Old Nov 22, 2012 | 09:50 AM
mopar204's Avatar
mopar204
Factory
Old Nov 23, 2012 | 10:21 AM
northgator8's Avatar
northgator8
Originally Posted by mopar204
Factory
Let's see if this works:
http://www.robagd.com/cars/robs/PDFs...all_Manual.pdf
Here is a link to the remote start intall manual. I know, it says for a magnum, but don't worry.
Go to the programing information and follow the instructions. It may have to re-learn some of the commands. My programing switch is a little red push-button tucked under the dash extension near the steering column. It is "installer's choice" so you may have to search around. Mine didn't work, then just started and quit, now works great, once I got the programing sorted out.
I have a better copy of the manual than what is shown in the link, but couldn't find a way to post, and forget where I found it.
Cheers!
Old Nov 25, 2012 | 12:06 PM
mattz's Avatar
mattz
Is there a hood switch? I thought I read somewhere that they can stick and prevent the starter from working. Worth taking a look.
Found it.
NUMBER: 08-014-05
GROUP: Electrical
DATE: February 17, 2005
SUBJECT:
Mopar Accessory Remote Starter Inoperative Due To Hood Switch
OVERVIEW:
This bulletin involves replacing the hood switch for the remote starting system.
MODELS:
2004 - 2005 (CS) Pacifica
2004 - 2005 (DR) Ram Truck
2004 - 2005 (HB) Durango
2004 - 2005 (JR) Sebring Convertible/Sebring Sedan/Stratus Sedan
2004 - 2005 (KJ) Liberty
2005 (LX) 300/Magnum
2005 (ND) Dakota
2004 - 2005 (PL) Neon
2004 - 2005 (PT) PT Cruiser
2004 - 2005 (RS) Town & Country/Caravan
2005 (WK) Grand Cherokee
NOTE:
This bulletin applies to vehicles equipped with a Mopar Accessories Remote Starter.
SYM [...]
