Engine noise like clicking and whirring
Old Dec 16, 2012 | 12:03 AM
italiandominator's Avatar
italiandominator
Default Engine noise like clicking and whirring
I hear clicking a whirring when I start my truck, not sure if its a sign that maybe the alternator or starter is going or what. Tried using belt dressing and didn't help. Gonna try using some lithium grease spray on the pulleys.
Any idea what it might be? It started once it started to get cold out. Goes away a lil bit when truck warms up but is still there
Old Dec 16, 2012 | 12:57 AM
06Dak4.7Silver's Avatar
06Dak4.7Silver
clicking could be the lifters..do you run synthetic oil? the hemi is notorious for the ticking but I can even hear the valves on my engine on a cold start
Old Dec 16, 2012 | 06:29 AM
erau's Avatar
erau
As stated above, the clicking is most likely the self-adjusting valve lifters after the oil runs out of them. The thinner the oil, the more prone. Known occurrence, generally considered normal by the technicians.
As for the whirring, it's probably the cooling fan clutch engaging for a short moment on startup. Without the service manual handy, I believe it has to do with the fluid in it draining out of the hub, or something to that effect. Should go away within about a minute.
Old Dec 16, 2012 | 09:08 AM
DaKoCuN's Avatar
DaKoCuN
Where are you?
How cold is outside?
When was the last time you change the oil?
What kind of oil do you use?
How many miles do you have on it?
Old Dec 16, 2012 | 10:47 PM
italiandominator
Yeah, I use synthetic oil. Mobile 1, change it every 5K miles. Weather hasn't been too bad. Was getting down just below freezing but last week or so about low 40's. truck has about 112k miles. Runs great overall though
