Prothane swaybar mounts, DONT BOTHER
Old Dec 16, 2012 | 05:43 PM
DM_kota's Avatar
DM_kota
Default Prothane swaybar mounts, DONT BOTHER
I bought some of these back in July when my other ones were in need of replacement. Pretty much avoid doing this if you can, doesn't seem to hold up worth a hoot. Now everytime I hit a bump my whole front end just rattles away... sad face.
That is all..
looks like I got a leak too.
Old Dec 16, 2012 | 06:00 PM
DaKoCuN's Avatar
DaKoCuN
Yes sir! There's a leak!
Old Dec 16, 2012 | 06:06 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
damn..I just put those on a few weeks ago
Old Dec 16, 2012 | 06:16 PM
DM_kota's Avatar
DM_kota
sorry to be the bearer of bad news.... hopefully you haven't thrown ur old ones away.
I might try to hammer mine tight again.
Old Dec 16, 2012 | 07:31 PM
damyankee84's Avatar
damyankee84
Maybe its me, but those brackets look bent on the top side....
Old Dec 16, 2012 | 08:34 PM
Yeah, your brackets are fubar. My bushings did great!
Old Dec 16, 2012 | 10:19 PM
06Dak4.7Silver
yeah, they are definitely bent. looks like a screwdriver was jabbed in there or something. Mine looked good when I installed them, hope the hold up. I do have the old ones in the garage if needed
Old Dec 17, 2012 | 09:34 AM
DM_kota's Avatar
DM_kota
Hey kids you might not realize this, but my mounts were nice and flat/tight too when I put them on 5 months ago...
cheap soft metal without reinforcement.
I am off to the JY on Fri for a 2nd Gen to see if they have the same brackets as a 3rd gen stock
Old Dec 17, 2012 | 11:19 AM
Apparently we did not. Good luck!
Old Dec 17, 2012 | 08:56 PM
thecause17's Avatar
thecause17
I've never had a problem with Prothane products and I had a full set installed on a Neon R/T that I had, including control arm bushings, sway bar bushings, end links, etc... They were good products.
What part number did you order? I don't see where Prothane makes a specific bushing for these trucks...
When I see that bent metal, I see improper fitment, leaving play either between the bushing and the mount, or the bushing and the bar. It looks like the bushing was allowed to twist or shift to one side and allow the bar to put force right on the mount and bend it. It has nothing to do with cheap or soft metal. I could be wrong, but I just don't think it's the right bushing. The OE bushings and the Moog replacements I've used on my truck have much more bushing material on each side of the mount that doesn't let it move. This is visable in your pic where the rust line is where the original bushing was sitting. I'd just take them out and put it some OE spec(Moog) replacements.
