What U-Bolts do I need to do Lift Blocks. Since Im replacing the U-Bolts anyway might as well.
Measure the axle tube diameter, the total length you want the U-bolts, and the diameter (rod size) of the current U-bolt, then you can go to a local spring shop and have new ones bent while you wait - they're usually a better quality than you get at a parts shop and no more expensive. Since they come in standard lengths, I get mine longer than I need and cut off the excess once the bolt is tightened in place.
Well..... i didnt get a 3.21... but i did get a 3.55 with a Posi and its an 07 with 40k miles. It was in a service truck for the local telco company and the fluid has been changed... this is awesome... $440.00
