gear swap project, need info
Old Jan 5, 2013 | 08:46 PM
Anthony Grego's Avatar
Anthony Grego
Default gear swap project, need info
so im noticing im having some leaking from the front of my rear diff where the pinion enters the diff from the drive shaft. figured the seal is going n is gonna need replaced n figure if im gonna have it opened up to do that might as well do the gear swap at the same time.
as of the time being i have the 3.55 ratio gearing, n frankly sucks off the line. i was figuring somewhere in the 3.90-4.11 gear ranges.
any suggestions as to which would be more favorable for some good off the line giddyup (ratio, brand, etc...)
also anyone know of someone in the charleston SC area that is able to do the install n well overhaul of the seals n gears. i dont have a garage anymore since i live on base.
Old Jan 5, 2013 | 10:51 PM
Tom A's Avatar
Tom A
Section Moderator
Changing the pinion seal is about a 30 minute job and you don't have to "open up" anything. You don't even have to drain the oil.
Old Jan 7, 2013 | 02:50 PM
Anthony Grego
huh no ****? k i was told by some dodge tech at the local dealer that it would require pulling the whole thing apart.
Old Jan 7, 2013 | 02:54 PM
Tom A's Avatar
Tom A
Section Moderator
Only if you need to replace the bearings.
Old Jan 7, 2013 | 02:58 PM
JimBio's Avatar
JimBio
Had mine done before, watched him do it in 15 minutes (once lifted). Its only a few bolts and one large nut I believe.
Old Jan 7, 2013 | 03:17 PM
Anthony Grego
eh still wanna do the gear swap at the same time might as well kill them both at once. any advice as to brands or ratios to go with i have 3.55 n they suck ***
Old Jan 8, 2013 | 11:19 PM
Deadsquiggles's Avatar
Deadsquiggles
Do you do a lot of highway driving or is it mostly city?
Old Jan 9, 2013 | 04:19 PM
Anthony Grego
mostly city driving, some highway(gas milage doesnt matter to me) some towing and traildriving and the occasional offroad
