Differential
Old Jan 7, 2013 | 10:13 PM
Deadsquiggles's Avatar
Deadsquiggles
Default Differential
I've looked everywhere I can think of and I didn't know where else to turn. So, here I am.
I'm trying to find out what kind of differential I have in my truck. My truck is 4WD so I figured at least a limited slip. But when I powerbrake it, even for extended periods of time, like 5 seconds or more, only one tire will spin. And if I gun it from a stop and it's wet outside and the tires spin for 5 seconds or more, it still only spins one.
Is there any way to find out what differential I have in there?
Thanks,
Tommy
Old Jan 7, 2013 | 10:41 PM
Tom A's Avatar
Tom A
Section Moderator
Jack up the back end, put it in neutral with the brake off, and turn one wheel by hand. If the other wheel turns the same direction, it's a limited-slip. If it turns the opposite direction, it's open (which it sounds like).
Old Jan 7, 2013 | 10:45 PM
jasonw's Avatar
jasonw
Site Moderator
Most of these trucks came without a limited slip, it was an option but not standard. Unfortunately, having 4x4 does not equate to having a LSD in the rear.
Old Jan 7, 2013 | 11:06 PM
Deadsquiggles
So it probably has an open diff?
Old Jan 7, 2013 | 11:19 PM
dakotaff's Avatar
dakotaff
Pm me your VIN, and I'll post your build sheet. It sure sounds like an open differential though.
Old Jan 7, 2013 | 11:26 PM
Deadsquiggles
pm sent
Old Jan 7, 2013 | 11:43 PM
dakotaff's Avatar
dakotaff
You have the same open diff like the rest of us, 'Corporate 9.25 LD Rear Axle'.
Some info:
3.55 gears
Tow package
Leather, heated seats, Infinity sound sys. (Nice)
I'll post up the whole list for you tomorrow.
Old Jan 8, 2013 | 12:08 AM
dakotaff's Avatar
dakotaff
Dodge Dakota (4x4) (Dakota LARAMIE/SPORT (US, Canada, BUX))
Vehicle equipped with: EVA 4.7L V8 MPI / DGE All 5-Speed Automatic Trans.
Built: November 08, 2004
Code Description
*LJ Leather Trimmed Bucket Seats
135S Zone 35-Washington
1AAS U.S. Dealer Retail
26J Customer Preferred Package 26J
2TJA Customer Preferred Package 2TJ
4X7A Virginia Chapter-90 Recovery
594S Vehicle Order Tracking
5I4S Four Wheel Drive (4WD)/(4X4)
5Z4S Club Cab
5ZCS Price Class P
5ZES 6 FT. Cargo Box
5ZZS ND-Vehicle Family
647S Virginia Ship to State Code
6USS U.S. Specifications Label
947S Virginia Sold to State Code
A82P 4.7L Eng (EVA)/5Spd A/T 5-45Rfe(DGQ)
ADJP Heavy Duty Service Group
AFHS Interior Convenience Group
AGG Sport Group
AHC Trailer Tow Group
AJBS Security Group
AJKS Convenience Group
AJPS Power Convenience Group
APAS Monotone Paint
BAZS 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BCSS Run Down Protection Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
CABP Bucket Seats
CBFS Premium Door Trim Panel
CDLP Manual Driver Lumbar Adjust
CFRS Rear 40/40 Folding Split Seat
CG3S Advanced Multistage Front Air Bags**
CGZS Passenger Air Bag On/Off Switch
CKES Front Seat Area Carpet
CL3S Luxury Front Floor Mats
CSRS Passenger Assist Handles
CSWS Driver Assist Handle
CUCP Floor Console
CUNP Overhead Console
-D5 Med Slate Gray
DGES All 5-Speed Automatic Transmissions
DGQ 5-Spd Automatic 545RFE Transmission
DHAP Lock-Up Torque Converter
DHTS Elec,Shift-on-the-Fly,P/Time T/Case
DJDS 205MM Front Axle
DMDS 3.55 Axle Ratio
DRBP Corporate 9.25 LD Rear Axle
EVA 4.7L V8 MPI Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEGS Deep Tint Sunscreen Glass
GFD Rear Sliding Window
GNDS Driver Side Sun Visor
GNES Passenger Side Sun Visor w/Mirror
GNTS Rear View Auto Dim Mirror
GUNP Power 6X9 Multi-Func F/Away Mirrors
GXRP Keyless Entry
GXXP Sentry Key Theft Deterrent System
HAAS Air Conditioning
I38S Route 38 - UP, Mesquite, TX
JA2S Instrument Cluster w/Tach
JAAS Instrument Panel
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JKWP 12V Center Console Power Outlet
JPBP Power Locks
JPDP Power Windows, Driver One-Touch
JPMP Heated Front Seats
JPSS Power 6-Way Driver Seat
K4AP STRIPE/BADGE/MOLDING/COLOR
K8AS STRIPE/BADGE/MOLDING COLOR
KRXS STRIPE/BADGE/MOLDING/COLOR
LACS Illuminated Entry
LAFS Key in Ign/Seat Belt Warning Buzzer
LAJS Headlamps On Warning Chimes
LALS Low Washer Fluid Warning Signal
LAMS Door Ajar Warning Lamp
LCHS Rear Dome Lamp
LMBS Halogen Headlamps
LMGS Automatic Headlamps
LNJS Fog Lamps
LPES Cargo Lamp
LPSS CHMSL Lamp
LSAP Security Alarm
MBAP Painted Front Bumper
MBDP Argent Rear Bumper
MFDS Bright Grille
MGAS Ram's Head Badge
MHAS Black Windshield Moldings
MTES Laramie Badge
MUMS Dakota Badge
NAS 50 State Emissions
NBKS EVAP Control System
NBQP Federal Tier 2, Bin 10A Emissions
NFBS 22 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHFP Power Steering Cooler
NHJP Exterior Mirrors w/Heating Element
NHMP Speed Control
NMCP Heavy Duty Engine Cooling
NZDS Next Generation Engine Controller
PSB Bright Silver Metallic Clear Coat
QSBS Bright Silver Metallic Clear Coat
RAQS AM/FM CD 6-Disc MP3 Radio
RC1S 6 Infinity Speakers
RD7P 276 Watt Amplifier
RDDS Fixed Long Mast Antenna
RDZS Steering Wheel Mounted Audio Ctrls
SBAS Power Rack and Pinion Steering
SCGS Leather Wrapped Steering Wheel
SDBS Heavy Duty Suspension
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHCS Front and Rear Stabilizer Bars
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TXVS P265/70R16 OWL All Terrain Tires
TZAP Goodyear Brand Tires
WD1S 16X8.0 Cast Aluminum Wheels
WDQP 16" Steel Spare Wheel
XBSS Pickup Box
XCAS Occupant Classification System
XDXS Scissor Type Jack
XFHP Class IV Receiver Hitch
XFKP 7 Pin Wiring Harness
XGDP Universal Garage Door Opener
XSLS Brake/Park Interlock
YAAS Build To U.S. Mkt. Specifications
YGSA 3 Additional Gallons of Gas
Z5HS GVW Rating - 6010#
ZAVP Spring - Left Rear
ZCFP Spring - Left Front
ZNVP Spring - Right Rear
ZRFP Spring - Right Front
Old Jan 8, 2013 | 10:37 PM
Deadsquiggles
Thank you very much.
I'm not sure what all the letters at the beginning of each listing mean, but apparently someone bought this truck with the intention of towing.
Old Jan 9, 2013 | 08:27 PM
jasonw's Avatar
jasonw
Site Moderator
The letters are just package IDs, basically, that Chrysler uses or used at one time.
