Full-sized double din in my 2006 Dakota
Old Feb 7, 2016 | 09:01 PM
rkircho's Avatar
rkircho
Just to verify one more thing: Did you have to cut out the thin plastic piece that sits between the radio cavity and the vents to install your double din navigation? Thank you
Old Apr 30, 2016 | 04:07 AM
rkircho's Avatar
rkircho
Did you cut the bezel with a file? I am trying that and it barely cuts the plastic. Is there something I may not be doing wrong to cut the plastic? My file is old. Do I need to buy an new one so It will work?
Thanks
Old May 1, 2016 | 10:30 AM
Vladek's Avatar
Vladek
files don't take much of a bite. plus there is a right and wrong way to use a file.
Old May 25, 2016 | 08:35 PM
rkircho's Avatar
rkircho
I'm installing a pioneer 8200 NEX nav in my 2005 Dakota. Is the red/black positive wire hot all the time or only hot when you turn on the ignition. Thanks
Old May 25, 2016 | 08:36 PM
rkircho's Avatar
rkircho
The red/black positive wire on the factory radio harness
Old Feb 29, 2024 | 07:22 PM
Joeysat56's Avatar
Joeysat56
Default looks great!!
Originally Posted by faynce
Here it is, folks. Did the custom work myself.
I'm not a professional, as you can probably tell.
Erik
Attachment 45798
Hey Erik what radio did you put there? I have 2006 dodge and want one like yours. I have the same set up . please let me know what is max size we can install one
Old Mar 4, 2024 | 12:47 AM
CHIZUCK's Avatar
CHIZUCK
I know this is a old thread but the jvc radio im looing at is only 2" deep. Do you all think sub dash still need to be modified?
