Next Generation Controller (NGC) fyi
Old Jan 19, 2013 | 10:20 PM
mulie4x4's Avatar
mulie4x4
Default Next Generation Controller (NGC) fyi
I was wondering what next generation controller meant on my build sheet found this, good info.
A powertrain controller consolidating both engine and automatic transmission controllers into one component. Designed by Chrysler engineers, it provides better coordination between engine and transmission functions for excellent performance.
The electronic architecture is substantially different from previous Chrysler controllers and is designed to expand technical capabilities in the future.
Old Jan 20, 2013 | 10:38 AM
06Dak4.7Silver's Avatar
06Dak4.7Silver
It's one DME that controls the whole powertrain so everything the transmission does is based off of what the engine does. Probably makes a much smoother ride and better response to throttle and brake
Old Jan 20, 2013 | 10:48 AM
Alfons's Avatar
Alfons
What years are covered by this controller & is it backwards compatible for the 3rd Gen Dakota?
Old Jan 20, 2013 | 01:12 PM
mulie4x4's Avatar
mulie4x4
Not sure, mine is a 2009.
Old Jan 20, 2013 | 06:29 PM
skybox's Avatar
skybox
Default NZDS on my build sheet
My truck is a 2005 and my build sheet says that I have the "NZDS Next Generation Engine Controller", but I don't know if it works or is any different from the one that mulie4x4 has on his truck.
Old Jan 20, 2013 | 08:19 PM
DaKoCuN's Avatar
DaKoCuN
So if I have the 2009 Dakota that means I do have this feature?
Old Jan 20, 2013 | 09:07 PM
jasonw's Avatar
jasonw
Site Moderator
It is pretty much a hyped up name for your engine's computer. The "next generation" naming convention started with the 4.7L engine's debut, if I recall correctly, in the 2002-2003 (ish) time frame.
If you have the 4.7L V8 in any third generation Dakota (2005+), you have this "feature". If you have the 3.7L V6, not sure. Maybe someone who has a V6 engine and their build sheet can chime in here.
Old Jan 20, 2013 | 10:12 PM
mulie4x4's Avatar
mulie4x4
I have the 3.7L v6.
Old Jan 21, 2013 | 08:35 AM
dakotaff's Avatar
dakotaff
I looked at a few build sheets, and it's on all of the 3rd Gen Dakotas.
Even the 2009 3.7 too.
