Emergency my truck wont drive sprayed drive belt with grease
Old Apr 15, 2013 | 02:36 PM
calixdakota's Avatar
calixdakota
no no , i added transmission fluid to my transmission. that was just a typo, that was a year ago.
and i had an oil change within 60 000 km.
edit, but you mean tranny fluid should be changedevery 60 km..
okay...well now i know, i ****edup..just hoping for the best diagnosis now...
Old Apr 15, 2013 | 02:41 PM
calixdakota
I used a white lithium grease...it should be fine...maybe i used to much . i read that if you use oil you could burn up the water pump or power steeringpump..
its at a transmission specialist now.If the reason that it started ****in up is because i sprayed the belt..thats pretty stujpid..and you think it would be fixable..but if somethings going wrong wit the tranny then i dont know, one of the guys suggested it could be a torque converter or something? cant remember exactly what he calledit..im just hoping they donttell me its not the tranny andthey dont kjnow what it is or cant fix it...had enough towage today...
Old Apr 15, 2013 | 02:50 PM
How many choices of places do you have to chose from for opinions on the fix?
Old Apr 15, 2013 | 02:54 PM
calixdakota
well at the moment i got it towed to the closest transmission specialist...dew-all transmissions...
other then that its any other tranny shop..or the dealership..so after i hear there dianosis in an hour or so or tomorrow..depending on what they come up with i may try and get another qoute from someone else
Old Apr 15, 2013 | 02:56 PM
calixdakota
that torque thing is what he said over the phone before i towed itthere from theshop that said the tranny was shot...
but they are idiots from what i have gathered..
Old Apr 15, 2013 | 03:41 PM
cheeseburger's Avatar
cheeseburger
you said it was smoking from the tranny fluid dipstick? Thats No Bueno...
Old Apr 15, 2013 | 04:24 PM
Alfons's Avatar
Alfons
If I had a transmission that smoked from it's dipstick, I would believe it was shot. A transmission shop will most likely give you a quote to repair or rebuild your existing transmission (they should also give you a warranty for this - should be about 1 year). If you want a cheaper price, you can get a used transmission out of an auto salvage yard - the tranny shop may be able to get one and install it for you for a cheaper price than a rebuild (the warranty will only be on the work the shop did, so you won't have anything on the tranny itself).
Old Apr 15, 2013 | 06:05 PM
Reject's Avatar
Reject
The only time My Transmission had this issue. I punched a hole thru my transmission pan and had Low Fluid. But it took about 5 seconds to engage in drive, I drove it 5 feet forward (into a driveway, as it happened on a turn) then turned it right off. It also wasnt leaking fluid very much until I had backed off the snow bank. Since the hole was packed with ice.
Once I got the Pan replaced, New filter and Fluid it was Just as good as before.
So Id say you drove it with Low Fluid, and Burned the Torque Converter or Pump
Old Apr 16, 2013 | 07:00 AM
calixdakota
Just spoke with the shop..there telling me to replace the transmission...and they can get one from a yard.. 1200 for the transmission an 1800 after install...and still need to get my power steering pump chekd out or it could just be a line.
if its the torque converter or pump that would essentially be better...how hardis it to find those parts to fit on a 07 dak?
Old Apr 16, 2013 | 10:30 AM
Neil Hall's Avatar
Neil Hall
Hit the serp belt with some carb cleaner to get the grease off and use proper belt dressing.As far as the trannie,too me it sounds like your torque converter is shot (much cheaper) because if it was the trannie itself you would experience difficulty putting it in gear... I will bet money on a torque converter steering is probably a bad rack if your pump is not seized (shouldn't be) or leaking.. process of elimination there if you did any rough offroading recently ill bet money on the steering rack too
http://www.oreillyauto.com/site/c/de...3248&ppt=C0338
