swap engines
Old Apr 21, 2013 | 03:52 PM
mrwhatshisname's Avatar
mrwhatshisname
Default swap engines
so can I swap a 4.7 into my 3.7 truck. do i have to change the tranny also?
Old Apr 21, 2013 | 04:36 PM
Reject's Avatar
Reject
Im 90% sure the transmission needs to be replaced with a OEM 4.7L One, or Aftermarket one compatible with the 4.7L.
You will also need the 4.7L PCM, ECU, and Engine Bay wiring Harness, and maybe even other stuff, If my 3.7L goes im Def swapping or buying a 4.7L haha
Old Apr 21, 2013 | 06:17 PM
jasonw's Avatar
jasonw
Site Moderator
Yes, you will need the tranny. The transmission in the 3.7L V6 trucks is not strong enough to handle the 4.7L V8's power/torque.
+1 for what Reject all said.
Old Apr 22, 2013 | 09:05 AM
donkeypunch's Avatar
donkeypunch
King Jackass
Lets find out if the original poster has an auto or a manual first. The manual is the same trans that was offered for the 4.7L.
Old Apr 22, 2013 | 01:55 PM
Alfons's Avatar
Alfons
Don't forget the drive shaft length(s) and transfer case if its a 4x4.
Old Apr 22, 2013 | 07:51 PM
jasonw's Avatar
jasonw
Site Moderator
Good point. Manual, he'll be OK. Automatic, he'll have to swap.
Old Apr 22, 2013 | 08:39 PM
mrwhatshisname
thanks for the replies, it is an automatic. I dont plan on doing this anytime soon. my truck only has 65k miles on it, so I hope I can make it to around 200k.
Old Apr 22, 2013 | 11:48 PM
donkeypunch
King Jackass
They are all the same, if memory serves. The 3.7L is just a 6 cylinder version of the 4.7L.
Old Apr 23, 2013 | 12:41 AM
Jaded's Avatar
Jaded
You're talking 10+ years down the road. As much as I like my Dakota, I hope we'll all be able to upgrade by then and not piecing these things together like Cubans.
Old Apr 26, 2013 | 11:05 PM
KS Cowboy's Avatar
KS Cowboy
why go with the 4.7? You will probably have a LOT to change, why not go 5.7? I mean if you are gonna do that much work, ya ought to do a little bit more. Just my .02 cents.
