Iac
Old Apr 30, 2013 | 07:06 AM
vantage08's Avatar
vantage08
Well I actually took off the TB and cleaned it prior to replacing the TBS and now the IAC. I went to put the IAC in and finally got it yesterday. I started it up even after disconnecting the battery and the idle dropped and stalled out. Is this normal for a new IAC? The reason I'm starting at teh TB is because of my cold start issue. It seems like it takes an extra crank or two now to start up. Then after its warm, it starts fine. Any suggestions? It has around 65k on it. I believe you need to change your oil after the seafoam correct?
Old Apr 30, 2013 | 07:56 AM
Jaded's Avatar
Jaded
Check your battery and charging system since low voltage is known to cause these problems also.
Old Apr 30, 2013 | 07:57 AM
It might take it a few driving cycles to relearn the idle.
Old Apr 30, 2013 | 08:00 AM
Jaded's Avatar
Jaded
When you say he had a bottle of cleaner hooked to his fuel rail, are you talking about "SeaFoam"?
No, not seafoam. This is a pressurized bottle of cleaner. They pull the fuse to the fuel pump and the vehicle runs off the cleaner.
Old Apr 30, 2013 | 09:54 AM
vantage08's Avatar
vantage08
Thanks for the advice! The battery is only a few months old. What do you think would cause the odd cold starts?
Old Apr 30, 2013 | 11:03 AM
Jaded's Avatar
Jaded
Check the starting system out. A problem there could discharge the battery enough to cause problems.
