Front Wheel Bearing
Old May 27, 2013 | 02:48 PM
Reject's Avatar
Reject
Default Front Wheel Bearing
Well this morning Im pretty sure my Front Passenger side wheel bearing went.
I also noticed both my front brakes scrape slightly aswell.
I get a loud grinding sound more at higher speeds over 80km (50mph) but also happens at lower speeds sometimes.
Anyone know the easier way to get to the bolts on the back side of the hub? I havent taken anything apart yet other then the tire of and sprayed abunch of PB Blaster on the bolts to let it sit since its raining (Covered everything with a bag to keep the rain from washing it off)
Old May 28, 2013 | 03:54 PM
Reject's Avatar
Reject
well got it apart other then the Hub, I cant get any of the 3 bolts to move, 1 of my Caliper bolts was SUPER loose to. I sprayed a TON of PB Blaster on it for now.
Old May 28, 2013 | 04:11 PM
They will come out eventually. Might need to use a breaker bar. Sometimes I use a dead blow hammer on a socket wrench to break them loose.
Old May 28, 2013 | 09:33 PM
Deer Hunter's Avatar
Deer Hunter
I bought 6 new bolts knowing that some were gonna snap. This wasn't my first go round swapping out hubs. Then I used a 3/4" breaker bar with a 24" handle. No problem, 3 broke loose and 3 snapped. Then i just used the 6 new bolts. Snapped bolts won't pose a problem removing the hub but, you are gonna need new bolts for the new hub.
Old May 28, 2013 | 09:34 PM
Reject's Avatar
Reject
Its tight to get one under there, and even then Ive had no luck yet.
Also adjusting the front brakes, its it easy? both my front pads scrap slightly, It took some wiggling to get the Caliper off the rotor.
Old May 28, 2013 | 10:40 PM
There is really no adjustment for disk brakes that I am aware of. Just make sure the slides are well lubricated. .
Old May 29, 2013 | 12:14 AM
italiandominator's Avatar
italiandominator
If you have trouble getting the caliper off in the future, use a flat screwdriver to get in between the caliper piston and the brake pad (but be careful not to snag the rubber piston boot) pry it back an forth a bit forcing the piston back into the caliper...then it should practically fall off.
Old May 29, 2013 | 06:39 AM
Alfons's Avatar
Alfons
Good advise - just remember to take the top off the fluid reservoir to make it easier. You can also get a small tool to do this for you but a wide, flat, screwdriver will do it. When the caliper is off, I usually take a C-clamp to push the piston all the way in to make installation easier - I use the old pad between the piston surface and the clamp.
If the screw driver won't push the piston back, you may need a new caliper.
Old May 29, 2013 | 10:58 PM
Reject's Avatar
Reject
I had both Calipers, Pads and Rotors replaced under a year ago.
Old May 30, 2013 | 06:34 PM
Reject's Avatar
Reject
well, Today I picked up the new hub, then broke the head off all 3 bolts of the old one. and it still wont budge. Then both my brake pads popped out of the caliper, 1 of the 2 pistons keeps pushing itself outward when pushed in it does it again and spills fluid out from around it when i try to push it back in.
