Aftermarket Radio and another Qs
Old Jul 29, 2013 | 11:19 PM
chasnasty's Avatar
chasnasty
Thumbs down Aftermarket Radio and another Qs
Hello all,
Trying install a Pioneer radio in my 2005 Dakota and running into same problems others are with the ACC power. Thinking of tapping into the Cigarette lighter power lead as others have done as this seems the simpliest. If i do this will i still be able to use the cig. lighter with the radio on without changing the fuse for it under the hood. Was also thinking of running a power lead from the battery and creating another fuse block for acc. inside the cab. Would this work? I think doing this it would be constant ON
Thanks everyone in advance.
Charlie
Old Jul 29, 2013 | 11:49 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
use the cigarette lighter..should be no problem!
Old Jul 29, 2013 | 11:53 PM
chasnasty's Avatar
chasnasty
so to be clear use the power from cig lighter and run it to the red or yellow on the radio.....thanks
Old Jul 30, 2013 | 12:35 AM
jasonw's Avatar
jasonw
Site Moderator
Correct. I could be misunderstanding the system, but from what I recall, the radio isn't actually drawing any power from the ACC wire. It is just telling it when to come on or not. Its a signal wire is all.
Old Jul 30, 2013 | 10:51 AM
Tygarys's Avatar
Tygarys
I used the cig lighter for mine.
Old Jul 30, 2013 | 03:24 PM
chasnasty's Avatar
chasnasty
so i'd run power from cig lighter to ignition power (switched power on the radio)???????
charlie
Old Aug 1, 2013 | 11:28 PM
chasnasty's Avatar
chasnasty
got it hooked up today and works great
Thanks everyone.
Charlie
Old Aug 4, 2013 | 02:17 PM
rebel4055's Avatar
rebel4055
I tapped into the cig lighter. No problems. Even put a spade disconnect so I can remove it.
