Needy help..
Old Sep 22, 2013 | 07:38 AM
pianist60123's Avatar
pianist60123
Good Morning Jason.. and thanks for your respond. I'll will be changing it today and will let you know.. Have a great Sunday, rain or shine, enjoy your day !!,,
Thanks..
Old Sep 22, 2013 | 08:20 PM
Tom A's Avatar
Tom A
Section Moderator
An ABS malfunction will not apply the brakes when you're not pressing the pedal (which is what I interpret your post to mean is happening). ABS only releases the brakes when it senses a lockup.
You either have loose parts in the brake drum, or something broken in the rear end (which could also damage the ABS sensor and cause the code). I'd start by removing the drums and inspecting the brakes. If everything looks good, I'd pull the cover off the diff and have a look inside.
Old Sep 23, 2013 | 09:24 AM
superdak05's Avatar
superdak05
your service 4x4 switch may very well be on its way out, its called the transfer case switch, these switches are known for having the wiring harness rub on the frt drive shaft and wearing threw the electrical coating that protects the wires to the switch, take a look under truck and see if your harness is hanging low and contacting the shaft
also if not, when was the last time you did a fluid change, could be time for a trans axle service
Old Sep 23, 2013 | 04:15 PM
pianist60123
Default ok ok
ok,so I 've changed the ABS sensor, I'm changing the rear brakes and now I'm going to check the trans axel.I have not changed the fluid. I 've own the truck 3yrs. now .
