Head light won't work
Hi everyone. Wednesday I came home from work and found out that the driver side low beam light was out. So today at lunch I took the head light out to find the back of the bulb had come out of the bulbs body. The bulb still work in low or high as you can now turn the bulb 180 deg and then plug it back in. So the bulb was good (maybe not in the best shape). So what I need to know for this weekend is,the middle wire ground or power? So is the power coming in on the middle wire and the high low switch ground the two other wires? Or the high low switch move a relay to add power to one or the other outer wires and ground in middle. Also were can I get some new pig tails for the headlight sockets
Sorry I guess I should have told everyone I got it fixed the night I posted. I did use my multimeter to find the problem it was the low beam wire had a brake in it at the socket so I went to autozone and payed for a new socket. Took that home and installed it. I was a dumb a$$ with the light. When I broke off the back and just turned it 180 deg it came on then. Then took it out and turned it 180 deg again it worked ,but it was on high beam.also I can't get the. Manual to down load on this forum it won't smell to install a download program so if anyone has it on a PDF file can you please send it to my email at garryburrell@yahoo.com and as always thanks for all the help guy !!!!!!!!!!'!
