Automatic Headlights
Old Jan 26, 2014 | 07:57 PM
timbo3875's Avatar
timbo3875
Default Automatic Headlights
In the auto position, headlights stay on all the time. Otherwise the switch works fine. Bad switch or bad sun sensor?
Old Jan 27, 2014 | 08:46 AM
Mine did too. I just used the switch to turn them on and off otherwise they never turned off. Never looked into it that much.
Old Jan 27, 2014 | 03:20 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Do they stay on even after your key is turn to the off position?
Old Jan 27, 2014 | 06:54 PM
timbo3875's Avatar
timbo3875
Yes, they do go off after a few minutes. Its not a major problem, just wondering if the sun sensor on the dash could be bad.
Old Jan 27, 2014 | 07:01 PM
Reject's Avatar
Reject
If your referring to at night, its normal.
When I turn my truck off after having the headlights on they stay on for a few minutes.
I dont have auto headlights, mine are manual. If I turn the truck off, then the headlights they will stay on for a few minutes as "courtesy lights"
Old Jan 27, 2014 | 07:31 PM
timbo3875's Avatar
timbo3875
When the switch is in the Auto position, mine stay on all the time, (day or night) until I turn the ignition off. Then they will stay on a few minutes and go off.
Old Jan 27, 2014 | 08:12 PM
Reject's Avatar
Reject
I would say the sensor might be bad, since they dont stay on when the truck is off. (Mine will turn off after 20 or so minutes if left in the ON position with the truck off)
Old Feb 21, 2014 | 08:45 PM
sinsee's Avatar
sinsee
Make sure your dash is cleaned off. If you have papers on your dash, it could be covering the sensor
