Major Trouble, sunk my Dakota
Old Feb 24, 2014 | 07:36 AM
Your papers are wrong. Or someone grafted an 08 front end onto your 07.
This is the 05-07 body style: http://www.google.com/url?sa=t&rct=j...61725948,d.aWc
08+ body style: http://www.google.com/imgres?client=...art=10&ndsp=21
Old Feb 24, 2014 | 10:34 AM
07DakotaBaby's Avatar
07DakotaBaby
If I'm gonna do this I might as well make it exciting. Any suggestions or references on what engine I should get?
Old Feb 24, 2014 | 03:53 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
If you are looking for a direct bolt, the 4.7 or 3.7. Anything else like a 5.7 you are going to need to invest some time and extra money.
Old Feb 24, 2014 | 05:52 PM
x2. Direct fit is another 4.7 or go small with the 3.7....if you want to drop in a hemi, read up on FrenicX hemi swap thread here > https://dodgeforum.com/forum/3rd-gen...-1yr-plan.html
Old Feb 25, 2014 | 02:05 AM
jasonw's Avatar
jasonw
Site Moderator
+3. That is a 2008+ front end, either your papers are wrong or the front end was converted to the 2008+ style.
Old Feb 25, 2014 | 07:44 AM
northgator8's Avatar
northgator8
Me and my brother just got a 2.5 in lift block lift and new Kenda mud tired with KO rims and the second day having them this is what happens
Looking though your other thread, it looks like you sucked water into your crankcase somehow and the ensuing hydraulic lock broke your rod, which then ventilated the oil pan.
Even if you had not met with a catastrophic internal failure, you would have likely fried some expensive electronic bits. These are pick-up trucks, with 4wd to get you out of situations, not off-road beasts to get you into situations
If you want to fjord fjords, you need to protect everything that is used to touching only air.
Old Feb 25, 2014 | 11:03 AM
Are you saying a 2.5" lift "block" for the rear axle or a 2.5" spacer for the front coil springs, or both? Another thing to consider, these trucks do not like spacers over 2" with 4x4. You will end up destroying the front end, expecially if you wheel hardcore, which apparently you do. Even with 2" if you continue to abuse the truck, it will make you pay.
Old Feb 25, 2014 | 03:50 PM
sgtjet's Avatar
sgtjet
I would never mud in my Dakota lol. Get a 4.7 and put a aftermarket cam in it. Good luck
Old Feb 25, 2014 | 09:40 PM
Tom A's Avatar
Tom A
Section Moderator
No way I would even consider mudding in my Dakota.
Old Feb 26, 2014 | 12:04 AM
rookie's Avatar
rookie
Hemi that thing. And raise the intake.
