Left brake and flasher not working!!!
Old Mar 16, 2014 | 01:44 PM
bobby_kimble1's Avatar
bobby_kimble1
Cool Left brake and flasher not working!!!
I'm totally confused since when I turn on my lights, it will go on, but it just would not get brighter if i stepped on the brake or wont blink if i turn on the signal. I have replaced bulbs and checked fuses. I'm at a loss what else it could be????
Old Mar 16, 2014 | 06:03 PM
LIZZRD's Avatar
LIZZRD
All other lights ? , parking, flashers ? right side all work ?
Old Mar 17, 2014 | 09:26 AM
What vehicle are you referring to?
Old Mar 21, 2014 | 04:06 PM
DodgeCACares's Avatar
DodgeCACares
bobby_kimble1,
Welcome to the forum.
I'd certainly like to look over some of the possible causes for this however I don't believe you've listed your vehicle model and year. I too would have checked fuses and connections, obviously not the solution here.
Please re-post with your vehicle details and I'd be happy to see what I can find.
Old Mar 23, 2014 | 09:43 AM
bobby_kimble1
its an 07 dakota slt ... yes all other lights and flashers working.
Old Mar 25, 2014 | 02:45 PM
Thank you. Moving to the correct technical section. Check the contacts inside the plugs for the bulbs. Sometimes they can get corroded or even heat damaged causing poor connection to the bulb.
Old Mar 25, 2014 | 04:23 PM
dakotaff's Avatar
dakotaff
Check the following fuses: 19, 43, 44, 51, & 55.
Gotta check to see if the pink/red wire at the tail light is getting power.
Old Mar 26, 2014 | 11:02 AM
kenttt's Avatar
kenttt
Have you tried a second bulb? Or tested the bulb w/an ohmmeter?
Old Mar 29, 2014 | 08:46 PM
bobby_kimble1
everything else works changed the bulbs fuses and flasher assembly no change
Old Mar 30, 2014 | 08:33 AM
Have you inspected the sockets as suggested? Have you measured to see if you have voltage at the plug as suggested?
