burning oil, oil around two spark plugs
Old Apr 2, 2014 | 02:01 PM
mlarson29's Avatar
mlarson29
Default burning oil, oil around two spark plugs
05 dodge dakota 4.7 awd quad cab with 166000km. it burns a puff of blue smoke on startup then goes back to regular. I did the plugs and found two fouled plugs both on the right head, thw one closest to the front and then two behind it. im wondering if its the valve seals or the plug gaskets. are thw plugs in thw valve head or in the cylinder head? what do you think it could be. most of the oil was around the threads and I have no coolant in the oil or oil in the rad plus no coolant loss.
Old Apr 3, 2014 | 12:05 PM
cheeseburger's Avatar
cheeseburger
Could be valve seals. Leaking oil down onto the valves. Does it use alot of oil?
Old Apr 3, 2014 | 02:48 PM
modernmuscle's Avatar
modernmuscle
I agree with cheeseburger, it could be the valve seals.
Old Apr 3, 2014 | 03:07 PM
Brian in Tucson's Avatar
Brian in Tucson
You need a valve job. And sooner rather than later. Motor oil burns significantly hotter than gas, so it will really put a lot of stress on the rings. And of course it you're fouling plugs, you're probably fouling the rings, too.
This is one of those things that if one side is bad, the otherside is doubtful. So plan on having both heads re-done. Figure new guides (knurling works but is kinda half assed,) at least new exhaust valves, and a gasket set which will include valve seals. Or find a cylinder head exchange and just use your heads as cores.
Sorry.
Old Apr 5, 2014 | 12:04 PM
mlarson29's Avatar
mlarson29
Sorry.
lol its not really economically worth it to get this done there only worth about six grand where im from and getting a shop to do it would robably cost 3 or more grand knowing a buddy got quoted 1700$ for a new head gasket. i think its time to sell to someone who wants it. but i could get two re manufactured heads off rock auto with everything for 550 a head that could always be an option.
Old Apr 6, 2014 | 11:01 AM
kenttt's Avatar
kenttt
You could try replacing the valve stem seals and see if that helps. If you're going to do some of them, you might as well do all of them.
Old Apr 22, 2014 | 08:02 PM
mlarson29's Avatar
mlarson29
well funny thing, it just stopped doing it. i added no oil additive just 1 litre of oil that it used at startup i presume. last Saturday i had let the car sit for two days as i did not need it and on monday it puffed out the biggest blue smoke cloud i have ever seen it do so i was like **** me. then when i started it after work nothing there. then since Monday night the smoke has not reappeared and the oil is still at the mark i filled it at. ii guess this lemmon of a truck threw me a bone for once.
