How to replace Aux power outlet
Old 04-09-2014 | 02:03 PM
Sometimes the inside gets corroded and stops making a good connection. Or, the positive pin on the bottom will break off. In that case, just replace it.
Old 04-09-2014 | 03:35 PM
Greatrack2012's Avatar
Greatrack2012
Originally Posted by Eimer123
You can use my how to paint bezel DIY, link in my signature. It shows how to remove it
Ok thanks ill take a look
Ok thanks
Old 04-19-2014 | 06:26 PM
Greatrack2012
I was finally able to get a voltemeter to check. I went in through here and it didn't read anything.
http://i1302.photobucket.com/albums/...psyycwci3a.jpg
any suggestions.
Old 04-20-2014 | 12:47 PM
Mickinator's Avatar
Mickinator
any suggestions.
Is that tape above it? It almost looks like someone replaced it before. If that is tape, take it off and see if one of the connections is bad. It's likely just twisted together. If it is, solder and heat shrink the joints and you won't have any problems.
If you measure across it and get nothing, assuming that you're measuring DC and not AC, then the problem is obviously upstream somewhere.
When you take the tape off, be careful not to let the wires cross. If they do, you'll likely blow a fuse. There's no need to add that to the list of things that could be wrong.
Good luck!
Old 04-20-2014 | 01:57 PM
Greatrack2012
I will have a look today and see. Thank you for the help, hopefully it is a simple fix
Old 04-21-2014 | 11:06 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Is your ignition on? Or do you have the fuse placed for constant power? I know that may be a stupid question...
Old 04-21-2014 | 01:54 PM
Greatrack2012
My ignition was on. It won't charge without power that I know of.
Old 04-22-2014 | 08:38 PM
dakotaff's Avatar
dakotaff
You can choose whether the dash power outlet 'stays on' at all times, or 'comes on with the ignition'. You simply have to shift the fuse in the fuse box to whichever way that you want the outlet to power up.
Click here for the pictures.
Old 04-22-2014 | 11:10 PM
Greatrack2012
I didn't know I could do that lol. The one that works in the centre console works only with the ignition. So I would a some the same for the one on the dash.
Old 04-22-2014 | 11:26 PM
dakotaff's Avatar
dakotaff
That's weird, the one in my floor console is always hot. Maybe that can be set up both ways too with a fuse placement.
Quick Reply: How to replace Aux power outlet
