Radiator tool?
Old Apr 24, 2014 | 10:09 AM
DABMIKE's Avatar
DABMIKE
Default Radiator tool?
Hello,
I have a 2006 Dakota 4.7L 2wd and the plastic radiator tank on top is leaking and I need to replace it. The transmission lines have a quick disconnect and I have never removed one of those before. When I asked at two local parts stores between the blank look and suggestions that I just cut them off, I was shown the display with different tools and told one of them should work, they just did not know which one.
Can some one tell me which tool will work as I am hoping not to buy the "master" kit with tools I may never use?
Thanks.
Mike
Old Apr 25, 2014 | 11:32 AM
italiandominator's Avatar
italiandominator
You need a quick disconnect tool. I had a similar issue when I was removing my radiator last summer and needed to disconnect the tranny cooler lines etc. I didn't have one at the time and was able to make a shim out of an aluminum can. They are cheap though. Basically, there is a locking ring that snaps into place when you insert the cooling line. The tool simply slides around and between where the line is inserted into the radiator inlet hole, pushing the snap ring out of the way, then it simply slides right out. I will try to post a pic of what a tool looks like, but there are several variations. A whole kit doesn't have to cost much...but, they can vary between $6-$25 depending on quality.
Old Apr 25, 2014 | 04:48 PM
DABMIKE's Avatar
DABMIKE
Thanks, that is the info I needed. I saw a set for about $12 like the one you pictured above I will pick up on the way home tonight.
Thanks again.
Old Apr 27, 2014 | 01:37 AM
italiandominator
No problem bro. It's the least I can do, after all the help I've gotten from so many others here on the forum.
