OK whats the pin called that holds in the shoes?
Old May 8, 2014 | 08:09 PM
daterxies's Avatar
daterxies
Default OK whats the pin called that holds in the pads?
last time a buddy and me replaced my PADS and 2 of the pins pretty much broke. He says you dont need the pins, that they are only there for guiding... is this true? I hear a clunk occasionally like my shoe or something hitting the caliper.
What are the pins called, if there even pins lol ?
Found them!
For anyone else ever searching for this...
Amazon.com: ACDelco 18K1740X Professional Durastop Front Brake Caliper Kit: Automotive Amazon.com: ACDelco 18K1740X Professional Durastop Front Brake Caliper Kit: Automotive
Last edited by daterxies; May 8, 2014 at 11:25 PM. Reason: accidently put SHOES meant PADS derpy derp
Old May 8, 2014 | 11:43 PM
LoCatus's Avatar
LoCatus
You mean THESE pins?
Brake Caliper Guide Pin
They ARE required.
Old May 9, 2014 | 08:24 AM
lol...if its the caliper guide pins, then yes, they are not optional. The calipers are two parts. One is bolted to the spindle, the other (which holds the pads and piston, etc) is bolted to the part thats bolted to the spindle using these pins. Without them, nothing is holding the pads in. You will have no brakes. I seriosly doubt the mechanical ability of your buddy at this point if he indeed is advising you that you do not need caliper guide pins.
The link you privided are the guide pin dust boots and the clips that go into the slots that hold the pads, you could do without them, but their purpose is to help keep the pads from sticking in their guide slots on the caliper. and, iirc, also reduce brake squeel. Usually if you buy pads, they include these clips (unless they are really cheap pads)
Old May 9, 2014 | 09:02 AM
daterxies's Avatar
daterxies
yea its not the pin that holds the caliper together, its the clips that keep the pads in place. I bought some Raybestos "Professional Grade" rotars and pads... i have been having a bad squeaking issue, just normal driving it squeaks when applying brakes and even when brakes are NOT applies going at slow speeds theirs some squeaking.
From what i read Raybestos are good rotars and brakes right? i always just went with the cheap autozone stuff but decided to get an actual name brand that ive heard about this time around and pay a little extra $$$
If the pads do come with the clips ill just return the amazon order.. they are pretty good with doing that.
Old May 11, 2014 | 07:44 AM
Eimer123's Avatar
Eimer123
The pad glides are kinda optional. They are there to be glides for the pads. Over time the bracket will wear down. They make different thickness glides to make up for the place. Also ever pad manufacturer is going to have its own specs on the pad ears so the original glides may not fit. You need to go to Napa or online and get a brake glide kit. It will have different thickness glides so you can find a set that fits.
