05 dakota tire pressure
Old May 30, 2014 | 06:17 PM
mlarson29's Avatar
mlarson29
Default 05 dakota tire pressure
i have a 05 dakota 4x4 awd quad cab with the 4.7L. its got the heavy duty suspension and a 2" receiver with the 265/65r17s. im wondering what the tire pressure is supposed to be as the sticker is gone on the panel and i have yet to check them since owning it.
Old May 30, 2014 | 10:38 PM
kenttt's Avatar
kenttt
Sticker on our 05 quad cab says 35 PSI
Old May 30, 2014 | 10:57 PM
dakotaff's Avatar
dakotaff
Heavy duty suspension is the only suspension, 35 is recommended with stock tires.
Old May 30, 2014 | 11:14 PM
No sticker, go with tire ratings.
Old May 31, 2014 | 08:12 AM
superdak05's Avatar
superdak05
I run 40 psi on my truck
Old Jun 1, 2014 | 12:12 PM
mlarson29's Avatar
mlarson29
well the quick lube place put it up to 44 psi and I started to vibrate which now I found out why. I dont vibrate at all after bringing them down to 36. I will fill them up again though to 40 if I need to tow.
Old Jun 2, 2014 | 10:15 AM
kenttt's Avatar
kenttt
I've found that the quik lube places don't always tighten the valve caps properly and consequentially they get lost. So I got in the habit of checking/tightening them after the fact. Haven't lost one since I started doing that.
Old Jun 3, 2014 | 12:49 PM
bchapin05's Avatar
bchapin05
Checked the tire place put 35 in mine. Just realized my tires are the new passenger rated Duratracs. So they shouldn't affect my mileage and have a 50k mile warranty. Sidewall appears a bit more rounded so I like the look of the heavier loads a bit better. But they ride really nice, are quiet, and were cheap. So if someone is looking for cheaper Duratracs you can grab the p rated for around 185 a tire.
