Engine sometimes spudders while stopped
Old 07-21-2014, 04:34 PM
steiner2142's Avatar
steiner2142
steiner2142 is offline
Default Engine sometimes spudders while stopped
I have an 05 Dakota, AT, 4x4 4.7l with about 90K miles. Occasionally while stopped at a red light with the vehicle in drive, the engine wants to spudder and rattle, and watching the RPM it goes anywhere from down to 300 up to 1000. It's only happened 3 times now but this last time the truck lurched forward a tad until I slammed harder on the brake. It will also go away as soon as I start to accelerate and it doesn't happen while idling in park. Any ideas? Fuel filter? Dirty throttle body? Spark plugs?
Old 07-21-2014, 04:47 PM
ODXBeef's Avatar
ODXBeef
ODXBeef is offline
My first thought would be to pull your throttle body and give your IAC valve a good cleaning.
Old 07-21-2014, 04:59 PM
steiner2142
I'm getting an induction cleaning which is scheduled for Thursday.
Old 07-22-2014, 09:03 AM
jkeaton is offline
Dodge Forum Administrator
Hopefully you're not paying someone hundreds of dollars for that "induction cleaning". You can easily pull the tb off and clean it and the IAC in very short time.
Old 07-22-2014, 09:37 AM
steiner2142
Nope. Still under warranty from the car dealer. Hopefully that's all it is, since it happens pretty rarely I don't want to run out of warranty before it's fixed.
Old 08-01-2014, 12:51 AM
ErikMissile's Avatar
ErikMissile
ErikMissile is offline
I've definitely seen the IAC valve cause these problems. It was amplified with the A/C on because of the additional engine load.
Quick Reply: Engine sometimes spudders while stopped
