Truck cap wiring?
Old Jul 31, 2014 | 10:01 PM
Zombifyd's Avatar
Zombifyd
Default Truck cap wiring?
Hello all. I know its been asked before, somewhat, but I just purchased a used truck cap and I'm trying to find the best way to wire the third brake light. I thought about right to the drivers side but don't want corrosion in the future, I thought about the 4-pin and 7-pin connectors, but it would make the brake light blink if I had a turn signal on while holding down the brake. What would be the best way to go about this?
Thanks!
Old Aug 1, 2014 | 08:24 AM
Mine had a 4 pin connector and it did not blink.
Old Aug 1, 2014 | 08:36 AM
Zombifyd's Avatar
Zombifyd
Hmmm I heard that was a problem. Did you just wire the cap tail light to the right side (or left side) brake light. I figured they would also be used as blinkers. If that's the case I returned the 4 pin already and got the 7-pin connector but has the same connections. But if I hook it up to a tail light it shouldnt blink? And out of curiosity, does our truck have that lone wire underneath (chmbl) for this purpose?
Old Aug 1, 2014 | 02:46 PM
I don't know. The cap already had the connector on it, I just pluigged it in.
Old Aug 1, 2014 | 02:48 PM
adamjeeps's Avatar
adamjeeps
There is a special wire already under your truck that is tied to the Center High Mount Stop/Brake Light. Mine was taped up under the bed near the bumper. This is the proper wire to tap for power for your truck cap.
Old Aug 1, 2014 | 03:54 PM
Zombifyd's Avatar
Zombifyd
Thank you! I went under there at lunch and found it. I knew there had to be something.
Old Aug 2, 2014 | 07:43 PM
djsilver's Avatar
djsilver
Be careful. My cap has a high mount tail and backup light. I don't know what the previous owner did, but it killed the circuit for the backup lights in the PCM.
Old Aug 5, 2014 | 11:24 PM
pyrofossil's Avatar
pyrofossil
I just rewired mine to install a flasher for the shell. Originally, I wired up a 3 pin towing harness into my towing harness so I could connect/ disconnect any time I needed. I was able to harness power for the brake light, which was always on w/ my running lights than got brighter when I applied the brakes as well as a separate power for my light inside the shell. I bought a new led brake light for my shell and a flasher, so I had to rewire it so it only came on when I applied the brakes. I haven't had any problems with my PCM. I also have 2 additional LED lights tied into my reverse lights.
Wish I would of know this... probably would of made my wiring a lot nicer and easier.
Old Aug 6, 2014 | 03:51 PM
.:Chainman:.'s Avatar
.:Chainman:.
you wouldn't happen to have a picture of this, would you? I looked under mine and I can't see anything resembling what you described.
Old Aug 6, 2014 | 05:25 PM
dakotaff's Avatar
dakotaff
Pictures are in this thread ----> Here.
