Custom suspension (mid/long travel) happening.
Old Mar 11, 2015 | 10:16 AM
  #61
rookie's Avatar
rookie
File Type: jpg
Old Mar 11, 2015 | 10:23 AM
  #62
rookie's Avatar
rookie
Old Mar 13, 2015 | 11:37 AM
  #63
rookie's Avatar
rookie
update: alignment shop is working with me. they say no problem; it will just take longer. also happy to find out that i put it together such that all the geometry is in the right ball park. no negative caster or positve camber or toe-out. the inspection is working out too, since i know the guy. Now, about those fiberglass fenders and 35x12.50s...
Old Mar 13, 2015 | 01:37 PM
  #64
donkeypunch's Avatar
donkeypunch
King Jackass
Would you take some more photos of your trim job up front? And hurry up with the 35's...
Old Mar 16, 2015 | 05:28 PM
  #65
rookie's Avatar
rookie
what do you need to see? it is a hack job. I basically cut just above the factory crease. i used to use body trim on the cut edge and it looked pretty normal. Amazingly the mud flap still worked. just trying to get the glass on now, so it looks like hell with no trim and no inner fender.
I decided on 34 10.50 17 interco LTBs (yikes). 35s are all 12.50s. they dont want to clear the upper balljoint/CA and i dont want anymore offset. i like a 10.50 on my 8" rims too.
Old Mar 16, 2015 | 06:14 PM
  #66
donkeypunch
King Jackass
Do 35x12.50s...don't you settle for less. If you dare stay with 34x10.50s, our dreams of seeing 35's on a truck with out the JMR lift, or body lift will be crushed forever...with no survivors! (Bane voice).
Old Mar 16, 2015 | 07:41 PM
  #67
projektdirtfab's Avatar
projektdirtfab
I was gunna say.....you already have front glass? Ill be selling my set once i finish the 1 piece front clip.
Old Mar 16, 2015 | 08:03 PM
  #68
rookie's Avatar
rookie
AHHH! too late; i would have bought those fenders.
Im gonna need another inch of off-set to clear my control arms with 12.50s. I really want to, but these 34s are not even an inch shorter (33.8 vs 34.5). the fenders are only 3" wider, and thats where i am now. 12.50s + another inch for spacing will stick out too much for me aesthetically. not to mention the 10.50s are over 20 pounds lighter, with deeper tread. But rest assured, 35s would fit fine.
BTW the truck is soooooo smooth now, with no bounce. i will need to hook up the back as it is coming off the ground now instead of the front.
Old Mar 16, 2015 | 09:00 PM
  #69
projektdirtfab
You'll enjoy the amount of travel with 33s or 34s way more than 35s. 35s roll over big rocks and obstacles like butter. But you lose so much travel because your tires will hit everywhere on full bump.
Old Mar 17, 2015 | 08:57 AM
  #70
rookie's Avatar
rookie
i dont think a .5" smaller tire is going to keep me from rubbing at full stuff. eventually i will try to chop and clearance for some more room. need about two inches at the fire wall and some of the support members for the hood/fender can be trimmed. i was also able to move the wheel forward with all of the adjust-ability of the new CAs for a tad more clearance. But it will have to hit pretty hard to get full bump. Especially since I have it set to about a 2-3" lift right now. i have more lift than before and still more down travel! Crazy.
FYI: these FOAs sing a bit. the dual rate slider squeaks a little sliding on the shock body. clocking the springs helped a bit, but FOA says it is par for the course. no complaints here.
