Rear Brakes
Old Dec 30, 2014 | 03:39 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default Rear Brakes
Has anyone know if there is a conversion kit for the rear brakes to switch from drums to rear disc brakes? The truck is a 2005 with a 4.7.
Old Dec 30, 2014 | 04:04 PM
I've read people converting using Ram brakes. There is a thread around here somewhere.
Old Dec 30, 2014 | 07:38 PM
master tech
Thanks, I'll check around some more.
Old Dec 30, 2014 | 08:02 PM
https://dodgeforum.com/forum/3rd-gen...rom-a-ram.html
One I could find.
Old Dec 31, 2014 | 06:14 AM
HillBillE's Avatar
HillBillE
Any idea what rear diff he has?
Disc brakes from a Jeep Grand Cherokee w/D35 diff will bolt up to the Chryco 8.25 axle.
May need a little cleaning on the center hole of the backing plate/caliper mount.
I used a Dremel tool with a sanding drum, took all of 3 minutes per side.
I got my brake set up from the 'U-Pull-R-Parts' for $50, the Grand had under 30K miles, and everything was like new.
Be sure and get the calipers, mount (backing plate) rubber hoses, rotors, etc. if pulling from a donor axle. And the four mounting bolts, as they are longer than the drum backing plate bolts.
ETA: You may need longer lug studs in the axle shafts!
The rotor is thicker than the drum where it mounts on the axle flange.
Old Dec 31, 2014 | 03:05 PM
master tech
He has the 9.25 rear differential.
Old Jan 1, 2015 | 10:47 AM
northgator8's Avatar
northgator8
Originally Posted by jkeaton
This thread is PURE SPECULATION. I have not done a conversion, but THINK it will be a direct bolt-on from 2003ish on.
