2 in drop on 4x4 Dakota2005 ???
Old 03-15-2015, 04:24 PM
slamdweetruck's Avatar
slamdweetruck
slamdweetruck is offline
Default 2 in drop on 4x4 Dakota2005 ???
Hi guys I'm new to page...
I saw some where on this page...that some lowered their dakota 4x4 ...I'm not look to totally slam it jus two inches all the way around...thanks for the help pics would help a ton..in live in south western pa...I don't off road ...only street driven
Old 03-15-2015, 04:42 PM
jkeaton is offline
Dodge Forum Administrator
Welcome to DF. Moving to the correct section. There's a couple of lowers trucks in this section.
Old 03-16-2015, 08:51 AM
superdak05's Avatar
superdak05
superdak05 is offline
mine is lowered, only in the rear to level out truck, nothing for the frt unless you cut the springs, lowering shackles at www.canuckmotorsports.com, also simple easy install you can do in your driveway, one thing I recommend is getting new bolts, with the amount of road grime, you may need to cut them off
Old 03-16-2015, 10:10 AM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
Dodge Forum Moderator
Get some cool awesome side steps and lower it visually.
Old 03-17-2015, 08:33 PM
h2ogunr's Avatar
h2ogunr
h2ogunr is offline
howz about a pic of the rear lowered superdak?
Old 03-17-2015, 08:51 PM
jkeaton is offline
Use a set of these to lower the rear:
Will look like this:
Old 03-17-2015, 10:46 PM
superdak05's Avatar
superdak05
my truck looks the same too
Quick Reply: 2 in drop on 4x4 Dakota2005 ???
