ECU Relearn?
Old Jan 31, 2016 | 05:19 PM
Soco3087's Avatar
Soco3087
So I just thought I would give you guys an update. I installed the new throttle body and accelerator pedal today, easy job only took 15 mins and I took everyone suggestions and disconnected the battery before hand and after I was done I did a quick relearn step I found on the ram messaging board. It said After the battery was disconnected for 30 minutes then reconnect the battery trun the key to the on position not the start. Slowly depress the pedal to the floor then back up watch the check engine light blink and go out then turn the truck off. Then start it. So I did that and truck ran just fine no need to go to the dealer. The only negative thing I have to say is after doing all that my original problem still existed, so yea it was a waste replacing all that but atleast I know thats new.
Old Feb 1, 2016 | 07:29 PM
Jaded's Avatar
Jaded
So what are you going to try next?
