wheels
Old Jul 20, 2016 | 11:02 AM
maxxiss's Avatar
maxxiss
Default wheels
I have a 2005 dakota 4wd no lift ans need to know if a set of rims with 0 offset fit .Backspace is 4.5 Thanks.
Old Jul 20, 2016 | 11:27 AM
dakotaff's Avatar
dakotaff
The wheels will fit. but it will be pushed out an inch from the stock stance. Stock wheel offset is 25.44 mm, the lower offset will cause some tires to rub when turning, not to mention more stress on the wheel bearings and wheel lugs. But some guys have put on wheels with a zero offset on their Dakotas.
Read these threads for some additional info.
The OFFICIAL Lift and Tire Size Thread
Rim and Tire Setup
Old Jul 20, 2016 | 12:06 PM
maxxiss's Avatar
maxxiss
Thanks
Old Jul 20, 2016 | 09:48 PM
maxxiss's Avatar
maxxiss
Default wheels
how about plus 10 offset and 5 backspace thanks
Old Jul 21, 2016 | 08:57 PM
Deer Hunter's Avatar
Deer Hunter
I had 265/70R16s on 16x8 rims with a +12 offset and 1/4" spacer with no rub. But I also had a 1.5" leveling kit. I now have 265/65R17 on 17x9 rims with -12 offset and no spacer. Had to trim about 3/8" off the bottom corner of the bumper. Tires are General Grabber AT2. A less aggressive tread may not have rubbed.
Old Jul 21, 2016 | 10:00 PM
maxxiss's Avatar
maxxiss
Thanks man
Old Jul 21, 2016 | 10:01 PM
maxxiss's Avatar
maxxiss
So you think i would be fine with 245 75 16 on it.
Old Jul 22, 2016 | 07:51 AM
dakotaff's Avatar
dakotaff
245/75/16 should be fine, but be aware that that size tire should be mounted on a 6.5 - 7.5 " wide wheel.
Old Jul 22, 2016 | 12:00 PM
pierrejoly's Avatar
pierrejoly
I had General Grabber AT2 in 245/75R16 mounted on my stock 16x8 wheels and it worked great even though General Tire ways 6.5 to 7.5 inch width. Keep in mind that not all tires will be able to hold up to that, so don't cheap out, but alot of other 245/75R16 tires do say 6.5 to 8 such as the Goodyear DuraTrac tires.
that extra half inch of wheel really just equates to an extra quarter inch that each sidewall has to come out by, which is not that much. i wouldn't run a 245/75R16 on a 9 inch wheel.
Old Jul 28, 2016 | 04:18 PM
maxxiss's Avatar
maxxiss
Thanks guys how do you think a 265 75 16 mud tire will fit on a16 x 8 5 inch backspace + 10 offset stock lift.
