2010 Dakota Towing
Old Apr 1, 2017 | 07:52 PM
mcarew's Avatar
mcarew
Default 2010 Dakota Towing
I have the 4.7 V8, auto 2wd. Need max towing capacity. Thank you.
Old Apr 2, 2017 | 07:55 AM
Google knows all.
http://www.ramtrucks.com/en/towing_payload/2010/
Old Apr 2, 2017 | 11:19 AM
dakotaff's Avatar
dakotaff
What trim?
Extended cab or Quad cab?
What Gears?
It does make a difference.
Old Apr 3, 2017 | 08:00 AM
mcarew's Avatar
mcarew
Default 2010 Dakota towing
Originally Posted by jkeaton
Thank you. The 7200lbs, I can tow my Volvo coupe on a U-Haul dolly? Volvo is 3300 lbs. I have a double set of overload springs on rear so it doesn't squat with my trailer. I set fwd, 1 set aft of rear axle.
Old Apr 3, 2017 | 08:03 AM
mcarew's Avatar
mcarew
according to the chart 7200 max
Old Apr 3, 2017 | 08:07 AM
As long as it's not over 7200 lbs.
Old Apr 6, 2017 | 05:24 PM
JCinTenn's Avatar
JCinTenn
I think you'd be good to go. I have an 07 4x4, 3.7 liter with 3.55 rear end. I once towed a twin axle trailer, about 16 ft long with a tractor on it. I am guessing the whole rig, trailer and tractor, was about 3500-4000 lbs. It did ok, I sure would have preferred the 4.7 but she did fine. If you're only towing the car and dolly around 3500 lbs you should be fine, especially since you have a 4.7.
Old Apr 7, 2017 | 11:50 AM
northgator8's Avatar
northgator8
Just remember, it ain't the goin' that's a concern, it's the stoppin'!
Old Apr 7, 2017 | 11:54 AM
JCinTenn's Avatar
JCinTenn
Truth! That was my main concern as I was pretty much at the limit of my max towing rating. I made sure to stay back off people and leave plenty of room to stop.
