suspension work
Old May 12, 2017 | 08:26 PM
Stephen Martin's Avatar
Stephen Martin
Default suspension work
I'm going to replace the shocks and struts soon myself (2005 4.7 4x4). I was wondering if there are any other recommended things to do to the suspension while I have those off? Specifically things that aren't too advanced or too expensive. Thanks
Old May 12, 2017 | 09:26 PM
Stephen Martin
would this pretty much cover it?
Amazon Amazon
Old May 12, 2017 | 10:17 PM
JCinTenn's Avatar
JCinTenn
Might as well do the stabilizer bar end links and stabilizer bar bushings while you're at it, won't add too much more to the cost. I just did all this plus hubs/bearings. I hope you don't have trouble with your lower strut bolts, they can be a pain!
Old May 12, 2017 | 10:33 PM
Stephen Martin
Thanks. I'm going to start with the penetrating oil a week or two in advance.
Old May 13, 2017 | 10:43 AM
dakotaff's Avatar
dakotaff
I hope you've done some reading here, and do not plan on replacing with OEM struts & shocks.
Old May 13, 2017 | 04:02 PM
Stephen Martin
Definitely not. Going with the monroe quick complete assembly in the front and KYB gas a just in the rear.
Old May 13, 2017 | 04:04 PM
Stephen Martin
would these two do it?
Amazon Amazon
Amazon Amazon
any idea of where to find the hardware kit for the stabilizer bar end?
Old May 13, 2017 | 04:17 PM
Stephen Martin
Here's everything I have so far...
http://a.co/2rblNR9
Old May 13, 2017 | 06:21 PM
JCinTenn's Avatar
JCinTenn
I bought everything from RockAuto.com. My tie rod ends, ball joints, and end links all had grease fittings on them. Originals did not. I bought the same struts as you and I love them. They did make the front a little higher than it had been, but I used Monroe shocks on the rear. My front is level with the rear, with no leveling kit. You're gonna love how it handles with all those new parts!
Old May 13, 2017 | 06:22 PM
h2ogunr's Avatar
h2ogunr
if it was me id loosen the lower nut but not remove it and beat it with a hammer if it moves proceed. if not get the bushings for the lower control arm, or drive the truck to the nearest cliff and give er a push
