Firewall hole for wire running?
Old Aug 6, 2017 | 02:55 AM
novak6991's Avatar
novak6991
Default Firewall hole for wire running?
Is there a hole on the driver side to run a power wire through the firewall for my amp? I couldn't find anything or maybe I didn't look hard enough. I have a 2006 Dakota Club Cab ST.
Old Aug 6, 2017 | 08:32 AM
erau's Avatar
erau
There should be a blank rubber plug just in front of the door (on both sides actually), instead of the firewall, which leads into the cavities just behind the kick panel cover. That's how I got my power cable through. Then from there, I ran it back under the rocker panel cover and then out the lower rear-side wall, where there was a plastic cap covering the panel port which would have been used to route and secure a rear seat belt (mine didn't have factory rear seats or belts).
FYI, if yours doesn't have rear seats either, the threaded hole in the floor behind that rear side panel (which would have been used to secure the lower seat belt strap) made for an easy wire ground (-) for the amp. I don't remember what thread size it is, but with a properly sized/threaded bolt from the hardware store and a wire ring terminal, it was easy as hell.
Old Aug 6, 2017 | 12:15 PM
Isn't there a rubber grommet over the hole that would be for the clutch linkage as well?
Old Aug 7, 2017 | 03:15 AM
novak6991's Avatar
novak6991
Do you mind posting a picture? I am kind of confused on what you mean.
Old Aug 7, 2017 | 10:40 AM
I can't, as I don't own one. But, on trucks with the third pedal, the linkage has to pass thru the firewall, generally there is a hole for that, but, even on the two-pedal trucks, that hole should still be there, just with a plug in it.
Old Aug 7, 2017 | 11:32 AM
Run it through the fender to the door then into the cab. Much easier.
IMG_20110213_142755_zps2d28e7eb.jpgIMG_20110213_142846_zps50e6b7be.jpgIMG_20110213_142912_zps2dac2394.jpg
