Spark plugs.
Old Oct 31, 2017 | 12:12 PM
Originally Posted by 15DodgeJourney
Interesting, as I was always under the impression that iridium is always the best since it has a longer life "knowing that you are choosing compatible iridium plugs with the correct gaping".
It seems this is a YMMV subject.
I used to be the guy that takes out everything OEM "if possible" and replace it with an aftermarket: Shocks, spark plugs, brakes, wheels, etc... With years I learned that I don't always get the best results with the aftermarket, even if they advertise better components. I did learn to stick with OEM yet I don't really listen
Engines designed to run on copper plugs generally perform best with copper plugs.
Old Oct 31, 2017 | 12:55 PM
15DodgeJourney's Avatar
15DodgeJourney
Indeed, but look how "for example" Rock Auto represents the spark plugs replacement for a 2nd generation Dakota. It seems as if the Iridium ones are the best replacement. Which I admit, was deceived by such representation and used to go far from OEM and how the engine is designed. I still have this bad habit in me every now and then
http://www.rockauto.com/en/catalog/d...park+plug,7212
Old Oct 31, 2017 | 01:09 PM
I've learned by trial and error....lol
