Turn Signal Issue
Old Oct 22, 2017 | 01:22 PM
rocvisionz's Avatar
rocvisionz
Exclamation Turn Signal Issue
Hey guys...need some help. 05 Dakota Club Cab. Dash light came on a couple of days of ago indicating bulb issue (round light with exclamation mark). My drivers side rear turn signal is out. Driving light works fine though. Using the turn signal causes the fast blink. All 3 of the other turn signals work fine. Replaced the bulb with 3 different brand new bulbs and none of them work. Checked wiring and everything is fine with no breaks or issues. Any ideas what could cause this problem? Can't be a fuse since all of the other signals work fine, can't be the socket assembly because the driving light works fine. Can it still be a bad relay causing just that one signal to not work?
Old Oct 22, 2017 | 03:19 PM
Still need to check the socket. There should be three contacts in there. Ground, running lights, and brake/turn signal.
Old Oct 22, 2017 | 07:41 PM
Jaded's Avatar
Jaded
x2 on the socket since you're from the northern area. Seen em rust out a few times causing bad connection.
