Starting issue in park
Old Nov 27, 2017 | 10:08 AM
roadster71's Avatar
roadster71
Default Starting issue in park
Periodically my 05, v6, auto, 4x4 does not know it is in park and will not energize the starter circuit. The park indicator light on the column does not light up but the truck is mechanically in park. It will start however in neutral. Where do I start looking?
Thanks
Old Nov 30, 2017 | 09:07 AM
roadster71's Avatar
roadster71
Can anyone help?
Old Nov 30, 2017 | 09:42 AM
If you wiggle the shifter, will the light come on? (and then the truck start?)
Old Nov 30, 2017 | 10:01 AM
roadster71's Avatar
roadster71
Yes, at times that will do the trick.
Old Nov 30, 2017 | 10:23 AM
It's probably an adjustment, or switch then. I don't have wiring diagrams, so, not sure where to point you beyond that.....
Old Nov 30, 2017 | 07:11 PM
roadster71's Avatar
roadster71
Thats what I figure too. Just would like to know where. In the column, Under dash, at the transmission?
Thanks
Old Dec 1, 2017 | 09:09 AM
Think I would start with the linkage, see if anything obvious presents itself.
Old Dec 2, 2017 | 09:32 AM
dakotaff's Avatar
dakotaff
Maybe the Neutral Safety Switch.
