throttle and cruise control cable replacement
Old Feb 3, 2018 | 03:17 AM
socalsean511's Avatar
socalsean511
Default throttle and cruise control cable replacement
2005 Dakota SLT 4.7L Quad Cab
i need to replace both cables, and would also like to accommodate with some extra length in order to install a throttle body spacer.
initial installation of the TB spacer rendered the cables too short by about 1".
the cable connector on the speed control cable is broken, and i can't believe how thin the plastic is on this piece...
anyway, i can't find OEM or substitutions/universal cables that will actually fit, so hopefully someone can help me...
thanks! sean
Old Feb 3, 2018 | 09:41 AM
Throttle body spacer on a port fuel injected motor does absolutely nothing. Waste of money.
See if you can get a part number from the dealership, then google search the part number, should come up with something.
