A/C issues
Old Apr 24, 2018 | 12:38 AM
iwindle's Avatar
iwindle
Default A/C issues
I have an 07 Dakota standard. When I turn on the a/c it blows hot only, like heater hot. I can hear the flapper moving when I switch from hot to cold and the a/c clutch engages when I turn on the a/c but it only blows hot. There is plenty of Freon in the system. Could it be the switch that turns hot to cold?
Old Apr 24, 2018 | 08:09 AM
More likely the temp door isn't actually moving.....
Old Apr 24, 2018 | 08:34 PM
iwindle's Avatar
iwindle
It sure sounds like it moving though. I also have the temp dial turned to cold so why would heat come through?
Old Apr 24, 2018 | 08:55 PM
If the lines under the hood are getting frosty, that part of the system is working, and the problem has to be in the box under the dash. Unfortunately, I don't know how yours works.....
