2005 Dakota Starting Problem
Old Apr 29, 2018 | 04:44 PM
Dakota Dawn's Avatar
Dakota Dawn
Default 2005 Dakota Starting Problem
my 2005 Dakota starts, runs great...then when I turn it off after it's been at operating temp for a while, it won't start again till the engine has cooled off, 30 minutes to an hour. It's not overheating, not running rough, not dying...have replaced the computer, wiring harness, o2 sensors...my mechanic is stumped.
Old Apr 29, 2018 | 04:49 PM
Probably cam, or crank sensor. Need to know what's missing when it won't start.
Old Apr 30, 2018 | 11:28 AM
Dakota Dawn
What do you mean by "what's missing" ? It'll crank and act like it'll start but then won't...the only thing that seems to cause it is the engine having been running for a while. I can drive 10-15 minutes and turn it off and it'll start right back up, if I drive 30 minutes or more then turn it off, it won't start again till the engine is cooled down.
Old Apr 30, 2018 | 01:24 PM
Whats missing: spark, fuel, etc. When it happens are you getting spark and fuel?
Old Apr 30, 2018 | 02:03 PM
Dakota Dawn
As far as I can tell, yes, it'll crank just like normal, even sound like it starts but then it stays at that moment, sometimes it'll start then die immediately. I've even tried holding the gas pedal down, not pumping it, I know that'll flood on fuel injection, but no difference...the only way to get it to start is to let it cool down.
Old Apr 30, 2018 | 02:35 PM
Actually, holding the gas pedal to the floor while cranking, will put it into 'clear flood' mode, and the PCM will DRAMATICALLY dial back on how much fuel the engine is getting. If you just press the gas a little bit, that'll put more fuel in, and also more air......
Old Apr 30, 2018 | 10:26 PM
djibara's Avatar
djibara
Could be a bad chip key have you tried another key?
Old May 1, 2018 | 04:43 AM
erau's Avatar
erau
Have any aftermarket sensors been used to replace factory sensors? These trucks tend to do weird things when non-factory sensors are used.
Old Feb 25, 2021 | 02:25 PM
Al W's Avatar
Al W
Default Solution?
Did you ever track down the source of the problem? I'm having identical issues with my 05 Dakota and am similarly stumped after running through the obvious solutions.
