Sway Bar Sizing
Old Jun 16, 2018 | 08:35 PM
Lbitchue's Avatar
Lbitchue
Default Sway Bar Sizing
Hello,
2007 Dakota SLT with the 4.7 liter flex. I'm looking to buy a front sway bar for my truck, as it currently does not have one (holes are all there, sway bar is just missing). I am seeing 30 mm, 32 mm, and 34 mm sway bars. A quick search showed no reasonable pattern for what size sway bar this truck should have, so I was curious what are on some other trucks out there from the model type.
Thanks!
Old Jun 17, 2018 | 02:51 AM
daktwos's Avatar
daktwos
You have to measure the diameter of your sway bar to be sure.Most trucks came with the 32mm sway bar.
Old Jun 17, 2018 | 07:12 AM
Lbitchue's Avatar
Lbitchue
Thank you for the response. I would measure the sway bar, but like I said, there simply isn't one on the truck, and I am buying the components (bar included) to install on the truck.
Old Jun 17, 2018 | 09:13 PM
daktwos's Avatar
daktwos
If you are 4x4 the previous owner removed it to get better suspension articulation for off-roading at the expense of very poor handling for the street most likely.
Old Jun 18, 2018 | 07:51 AM
32 mm.
Or go to a junk yard and get one off another Dakota, or, they are all over ebay.
https://www.ebay.com/sch/i.html?_from=R40&_nkw=2007+dodge+dakota+sway+bar&_ sacat=0&LH_ItemCondition=4
Old Jun 18, 2018 | 08:11 PM
Jaded's Avatar
Jaded
Previous owner did the sway bar delete. https://dodgeforum.com/forum/3rd-gen...ar-delete.html
