Caster camber bolts
Old Sep 30, 2018 | 12:26 PM
Robb Erts's Avatar
Robb Erts
Default Caster camber bolts
On a 2005 Dakota, which is the caster cam bolt on the lower control arm? The front one or the back one? Thank you.
Old Oct 1, 2018 | 04:45 PM
It's a balance, moving one will change both caster, and camber. Gotta play with 'em to get the settings in the right spot.
Old Oct 2, 2018 | 08:26 AM
northgator8's Avatar
northgator8
Why do you care? I just changed the left ball joint, and on re-assembly and lubrication, discovered that both tie-rod ends were just about worn out. Since I would rather do it in September than February, I replaced them both.
Used a tape measure to get the alignment close, then drove to Canadian Tire for a late Sunday afternoon alignment. Camber and caster were slightly out of spec on initial measurement, and were the same when delivered to me. These don't move without breaking once they have a little life in them! I saw the alignment guy get the big bar and give it the old college try, but nothing.
Old Oct 2, 2018 | 07:53 PM
dakotaff's Avatar
dakotaff
Follow the link to the Service Manual below (above the picture), and download it.
Alignment info starts on page 32.
Old Oct 2, 2018 | 09:52 PM
Robb Erts's Avatar
Robb Erts
Thank you.
Old Oct 2, 2018 | 09:53 PM
Robb Erts's Avatar
Robb Erts
Thank you much.
Old Oct 2, 2018 | 09:54 PM
Robb Erts's Avatar
Robb Erts
Greatly appreciated.
