Noise rear end
Old Dec 15, 2018 | 10:18 PM
stetson's Avatar
stetson
Originally Posted by Seventime
k thanks for the advice. I’m gonna change out the links/bushing’s since I’m under there any way and see what happens.
So, bearing noise will cause a clicking/pop noise? Is that the bearing where the drive shaft yolk goes into the rear pumpkin?
they can when damaged its not exactly common, it usually progresses to a ball bearings in a blender sound followed by loud obnoxious squalling. When you think about it a ujoint is just 4 bearings on a post afterall. bearings are famous for only making noise when under a load aswell. Yes the pinnion bearing is the one i would suspect but you would have noticed slop in the bearing when you checked the ujoints. Are you sure that its coming from the rear end?
Edit i should add its not the bearings that make clicking popping sounds they just allow things to move around enough to make the sounds. ( their the cause)
Old Dec 15, 2018 | 10:26 PM
Seventime's Avatar
Seventime
The noise definitely seems to be coming from the rear end of the truck. As I mentioned earlier there is a ton of slack/play in the stabilizer bar, bushings and links. Which definitely does not seem normal?
Old Dec 17, 2018 | 08:47 AM
northgator8's Avatar
northgator8
Originally Posted by seventime
the noise definitely seems to be coming from the rear end of the truck. As i mentioned earlier there is a ton of slack/play in the stabilizer bar, bushings and links. Which definitely does not seem normal?
not normal!
Old Dec 18, 2018 | 07:18 AM
stetson's Avatar
stetson
Originally Posted by northgator8
not normal!
x2 definitely get that fixed first. Or take them off and run around the block and see if the sound goes away
Old Dec 18, 2018 | 09:01 AM
Seventime's Avatar
Seventime
ordered all new links/bushings. They should be in today, then try and install them between kids hockey/Christmas stuff.
Will keep posted.
Old Dec 18, 2018 | 12:44 PM
northgator8
Will keep posted.
I hear you about how busy things are at this time of year, but you want it fixed to haul gear to the hockey tournaments!
If the links take you longer than half an hour, you are doing it wrong . . . . LOL. I haven't done the bushings, because mine are okay, but I don't think they will take much longer.
Old Dec 18, 2018 | 02:30 PM
Seventime's Avatar
Seventime
yeah im sure it will be a straight shot. You happen to know the torque specs on the links if there is any
Old Dec 18, 2018 | 05:08 PM
dakotaff's Avatar
dakotaff
Check page 39 of the FSM, linked below.
Old Dec 19, 2018 | 07:14 AM
northgator8
two and a half ugga duggas on the impact driver or a little angry on the 1/2" ratchet
Old Dec 19, 2018 | 09:25 AM
Seventime's Avatar
Seventime
Checked the FSM. Thanks!
