Drive shaft issues
I have a 2010 Dakota, 2WD ST. I have been experiencing some vibrations when i hit 35. I have done the speed test in 1st and 2nd and there is no vibration. Only in drive. I have changed all 3 u-joints and replaced the center support bearing. I did notice some play in the companion flange on the differential. Is this normal? There is no fluid leakage though. Also, is it possible to convert from a 2 piece drive shaft to a single drive shaft.
High frequency vibration like a buzz or low frequency vibration like a wobble or slow shake?
The drive shaft will be at the same rotational speed at 35mph for any gear so I would lean towards a trans or engine issue versus a driveshaft issue. Something like how the TCC hesitating to engage when accelerating. Maybe a loaded misfire that mostly shows at low load, low RPM. Like 35mph in third versus accelerating harder and still being in 2nd at a higher RPM at 35mph.
Is the vibration only there when accelerating to 35 or do you feel it when your speed gets down to 35 when slowing to a stop?
Rodslinger: Its a wobble. Happens when I accelerate, haven't noticed anything when I'm slowing down. Also, its intermittent. Sometimes when I go 35 or more, there is nothing. Then when I slow down and have to accelerate again, the vibration returns.
Maintenance is current. I will try the tow/haul mode to see if it makes a difference. I love this truck and don’t want to go spend $50k on a new one when this one is still in great shape, mechanically and visually, with the exception of the vibration I am experiencing.
Trending Topics
Automatic transmission fluid. Pump / Torque convertor are slightly starved. The level is low, the pickup filter is cracked or plugged, or the fluid is past useful life and is time for a changeout service. Suggest you start there.
