Help!! Ball joint and bushing project failure
Old Feb 17, 2019 | 06:57 PM
DogOne's Avatar
DogOne
Default Help!! Ball joint and bushing project failure
2005 Dakota 4.7 RWD is torn apart in the garage, can't get bushing out of the lower control arm, and can't get the ball joint installed because "just rent a kit from the auto parts store" is missing most of the sizes I need.
I checked 3 other stores and no one has the right size adapter for the receive side of the ball joint press.
No one has an adapter big enough to to go around the outside of the control arm busing.
No one has the right size to go around the strut bushing.
Can someone PLEASE give me some information about where to get these?
Old Feb 17, 2019 | 07:45 PM
pilotsmack's Avatar
pilotsmack
Whereabouts are you located? Perhaps a member near you could drop one off for an afternoon.
Odd that their kit doesn't have the right size. I got mine from Princess Auto (like Canadian Harbour Freight) and it came with everything and did the job fine.
Old Feb 18, 2019 | 09:04 AM
Bushings are damn near impossible to remove. You need a press.
Old Feb 20, 2019 | 08:19 AM
DogOne's Avatar
DogOne
Yeah I had the press, the problem is having the right sized adapter cups.
I'm resigned to buying random master adapter sets until I find the right ones, I refuse to accept that this can't be done,
If I'm having this problem, everyone else is too, because I checked the loaner sets at 4 different auto part stores and all of them were wrong in the exact same ways.
Old Feb 21, 2019 | 11:41 AM
Jaded's Avatar
Jaded
Those auto parts store loan tools get abused. I tried years ago, c clamp was stripped in the kit I got. Wasted enough of my time - bought my own.
Old Feb 22, 2019 | 11:57 PM
rodslinger's Avatar
rodslinger
Default Try a drill bit
I've used various variations of the video below. I've also drilled out the center sleeve with a hole saw which makes it easier to collapse the outer sleeve and knock it out.
https://youtu.be/oZ9IKbRu91o
Old Feb 23, 2019 | 08:53 PM
DogOne's Avatar
DogOne
How do you collapse the out sleeve, a hammer and chisel?
Old Feb 23, 2019 | 11:39 PM
rodslinger's Avatar
rodslinger
Usually. Once you core it the rest of the bushing has more room to collapse. I just take a big effing hammer and a chisel to drive between the outer sleeve and control arm.
This guy below uses an air chisel same concept. Just bash that bastard out.
https://youtu.be/P7PvxtVLTKs
Old Mar 2, 2019 | 08:50 AM
RicOshea's Avatar
RicOshea
Or you can just take it to your local garage and they will press them out for you with minimal charge. I would be more inclined to go that route instead of "core drilling" the old out. Hole saws tend to wander and even the best set will have some elliptical irregularities. I had 2 front wheel bearings stuck in the spindles and my local pressed them out for less than $20 CAD.
Old Jun 19, 2019 | 12:35 AM
DogOne's Avatar
DogOne
I got a shop to do this, because it was turning into a nightmare. He charged me 2 hours of labor, over $250.
That included removing everything and installing my parts. A net gain, but not by much.
