failing alternators
I have an 06 dodge Dakota. In the last 6 months I have replace the alternator 3 times. I replaced one the first of December that lasted about 2 weeks. The second one lasted from December to the end of May. I just replaced it again just a week ago. Itis now making a high pitch whining noise. My question. What would be causing the alternators to fail?
What brand do you keep getting?
Trending Topics
I would agree with bad alternators.
I would also have the battery tested....dead/bad batteries will make the alternator put out more amps....ever check the amp output when you start a car with a dead battery...15-20 for a normal system 60 to 70 with a dead battery. Alternators are designed to maintain a charge level...charging a completely dead battery from the vehicles charging sytem work them hard.
